Post Questions/Problems In This Thread
/ Post Questions/Problems In This Thread #141
PineRidge said:
I seem to be having an ongoing intermittent problem with click throughs. If I click on a thread sometimes it will never open. At that point I hit stop, back, then try again. Sometimes it takes two or three tries to see the thread that I want. Is anyone else experiencing this type of slowdown?
I posted about the same type of problem about the end of July. Seemed to get a little better, but it's off and on. There was no response then, and I thought maybe others weren't having the problem...
/ Post Questions/Problems In This Thread #142
sounds like we're all having this issue -- I generally do TBN first thing in the a.m. at my desk --- through the lan - on a frame relay -- so I know it's not my throughput. I get hangs everyday -- changing threads, trying attachments, doesn't seem to be a pattern of any specific links -- but all.
/ Post Questions/Problems In This Thread #143
We're trying to figure this issue out. Please be patient. :)
/ Post Questions/Problems In This Thread #144
patience is most likely exactly what it will take to find the glitch(es) causing this. like I said above - doesn't seem to have a pattern - random acts of error ...... that kinda thing drives me nutz trying to find. .... wishing y'all all the luck I can muster. ---
/ Post Questions/Problems In This Thread #145
Yep, those intermittent problems with anything can drive you nuts. And this particular problem occurs for me maybe 10 to 15% of the time.
/ Post Questions/Problems In This Thread #146
This prob was fixed for awhile, but is back: when looking at a pic, the return takes you back to the top of the thread instead of the one you were looking at prior to clicking on the pic. Just thought i'd let you know.........
RD
/ Post Questions/Problems In This Thread #147
RD
That's been happening here also but I actually thought the problem was on my end.
/ Post Questions/Problems In This Thread #149
mudcat said:
Happens here also.
I've been avoiding that prob by right clicking pics and opening in another window.
Soundguy
/ Post Questions/Problems In This Thread #150
Soundguy
That's the only way that I have found to get around it.
/ Post Questions/Problems In This Thread #151
Soundguy
This is something that has been driving me goofy and duh, the fix avoided me.:eek:
Thanx Soundguy:D
/ Post Questions/Problems In This Thread #152
Thanks for turning on, fixing or changing what ever it was, so that my signature works. :):):)
/ Post Questions/Problems In This Thread #153
/ Post Questions/Problems In This Thread #154
That should be working now. Try the link again from the e-mail.
/ Post Questions/Problems In This Thread #155
Yep, works fine now.
thanks
Soundguy
/ Post Questions/Problems In This Thread #156
Ok.. another odd one. it is 9:52 am est time. All of a sudden when i click a link to a thread from an email notification.. or manualy navigate and click a link to a thread I've been reading.. i no longer go to the last read message.. I go to the 1st message. 10 minutes ago this was working fine.
Also.. I keep getting email notifications about a reply .. i click it.. and there is no new email. I'll post 2 examples.
I've gotten at least 3 copies of each of these.. each show the same 'new' message number... and in each case.. it is an old message.. not a new reply.. same number in each link in each of the 3 messages. for both of these..
http://www.tractorbynet.com/forums/showthread.php?t=86174&goto=newpost
http://www.tractorbynet.com/forums/showthread.php?t=84882&goto=newpost
EDIT: I've now just recvd the 4th copy of these.. same link.. no new messages though. 10:01 am est
Soundguy
/ Post Questions/Problems In This Thread #157
Perhaps a related issue. When viewing a post from a email notice link.. the page is showing.. but the replies ar not unless i go out to the forums.. and then go in manually.. then the new post shows up... weird..
Soundguy
/ Post Questions/Problems In This Thread #158
In a forum.. but not a thread. the 'advertise here' is pushing the page number out.. thus making the page 3" wider, and making the screen scroll side to side.
Anyone else seeing this?
I tried an exit and reload.. no help. No other problems on other websites. Only happens browsing the thread list... looks ok in a thread.
Soundguy
/ Post Questions/Problems In This Thread #159
Soundguy
That's fixed now.
/ Post Questions/Problems In This Thread #160
Whe I click on "forum tools" (which used to get the pull down and mark the firum as read) it just jumps me to the bottom of the page.
How do I mark the forum read now?
Cliff
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
(4) SIDE BOXES (A63569)
(4) SIDE BOXES...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59910)
2018 VOLVO VNL...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
