Portable Sawmill
/ Portable Sawmill #21
Well Shawn, that's a question the CEO asked me the other day and here's my best guess.
New 13hp Kohlor Motor(off ebay) $250
Various parts for the motor/drive $45
Acme screws/nuts/bearings(for raising the table) $40
New 12' Unistrut channel $20
2 tires and rims $40
4 v pullies for the wheels $15
Misc channel/angle steel purchased $25
Countless bolts/nuts/washers $15
So, around $450 including the engine, and NOT including the blades.
TIME...<font color=red> PRICELESS </font color=red> /w3tcompact/icons/wink.gif
The majority of the steel I used I had on hand already or I used some scrap from the welding class. I used my welding class time to work on most of the frame construction, so I was learning while building. So most of my 7018, 6013, 7014 rods where from the class.
But really the "time" I put into this project, like most larger projects I've done, from what I know now, I could cut my time in 1/2 on the next one....
There are a couple of changes I might make on #2. One of which would be to route the drive pulley to a axial mounted to the rear of the table. Of course, I'd have to add a few more bearings, but it would simplify the drivetrain and I believe this is the way I've seen the commercial ones do it. Also, this would allow you to "mount" any size pulley to the axial, and that would allow you to change FPM of the saw blade very easily.
But that's another day. Right now I'm trying to figure out what I want to do for my track. The permanent home for it isn't ready yet and I need to cut some logs for my barn in order to dry them out for using them this summer. I will have to purchase some 20' 1"x1" 14ga angel steel for this, but that shouldn't be but another $25.
Suppose to be nice this weekend, I'll probably cut some more then and snap a few pics.
gary
/ Portable Sawmill #22
If you are thinking of using angle for tracks, I would suggest that angle is far from straight. Channel is a bit better and tubing is best, right off the rack. I'm talking about hot rolled here. I haven't bought enough cold rolled to know if its better, but I suspect it is. As you know, your saw will only cut as straight and flat as the tracks it follows. The straightest thing I know of right off the rack is any shape extruded aluminum.
/ Portable Sawmill #23
Last night I finished adding a motor system to my table to raise and lower the saw with the flip of a switch. I got a motor for $20 off ebay to power it and another $20 in sprocket and chain.
I can raise the table 1" in 11 seconds with the 5:1 gear ratio I've got with the 12 tooth drive sprocket and 60T sprocket on the screw. I may try to go with a 18T drive sprocket to see if the motor will handle the load and perhaps get my time for 1" down to 7-8secs.
Pictures coming later.
Has anyone found a good source for drive sprockets. My shaft is 1/2" and most of the sprockets I've found are for go-carts and have a 5/8" or larger bore.
Grainger.com has a good source but they want $9-$12 for them.
thanks
gary
/ Portable Sawmill #24
sorry all, it's taken me so long to follow up this post. here's one picture of the motor and gear from the front.
/ Portable Sawmill #25
here's a picture from the rear. motor attached with the 4 bolts.
g
/ Portable Sawmill #26
here is the reason why I've been very busy...
There is a building near my work office that they are going to tear it down and it had a bunch of labs that had these metal cabinets. So I got permission to cockroach these cabinets and a bunch of other stuff.
Most of them are blue, but I want to paint them to red. /forums/images/graemlins/smile.gif
g
/ Portable Sawmill #27
Here's a few more that I've got them out my garage.
/ Portable Sawmill #28
here's one side of my poor garage. FULL!!! /forums/images/graemlins/shocked.gif
Some of these will be going to my barn when I get it build this summer /forums/images/graemlins/wink.gif
/ Portable Sawmill #30
I built a portable saw mill last winter. I never used any plans just some photo's I found on the web. The mill is a chainsaw mill that can cut up to 30 inch diameter and up to 12 ft long. This is perfect for fence posts. I want to sell this one and build another.
/ Portable Sawmill #32
no picture scott....
/ Portable Sawmill #34
Here is the frame of the saw mill. Finally got the pictures re-sized.
/ Portable Sawmill #36
Very nice, did you start with the trailer part then proceed to the saw or is this just the first of many pictures?
How did you square the trailer up, some carefull welding/tacking?
What's that axile rated for?
thanks
gary
/ Portable Sawmill #37
Yes, since this was my first big welding project I started with the frame first. I purchased all the steel cut to specific size. It was more expensive but I didn’t have any thing to cut the steel at that time. I basically tack welded all the sections on and with a t-square and level checked it. The length is 16’ and is supported by the four tube steel columns I have at each end. This holds the weight of the logs. I usually lift the frame off the ground a few inches and level it before I start milling. I’m not sure what the axle supports since it only supports the sawmill frame. It was a left over axle my father had. I will post some photos of the saw. I built a chain saw mill thinking a band saw mill would be too difficult. After completing it I realized the band saw mill wouldn’t be that bad. That is my next project. I will send some more photos.
/ Portable Sawmill #38
Scott, I'd be happy to send you some detail pictures of mine with idea's to improve the setup. I started out just the opposite from you, I built the cutting head first and now slowly getting the track system created. I just wanted to have a little proof-of-concept first before jumping in with both feet.
I'm creating a semi perminant set of tracks out of 4"x18' cast iron water pipes left over from a construction site. They are super rigid and HEAVY. I'm going to bolt a couple of angle pieces to align them and then used RR ties to support the logs.
It's been too rainy and wet here the last month to do anything that's not on solid pavement.
gary
/ Portable Sawmill #39
That would be great! I definately need ideas on building the cutting head. Here is my e-mail address. scbarret@nortelnetworks.com. I posted some additional photo's of the building phases and my design of the cutting head.
/ Portable Sawmill #40
Here is a cap weld on tube steel. I was proud of this one so I figure I'd add it in. /forums/images/graemlins/smile.gif
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
1999 FREIGHTLINER FLD70 ROLLBACK (A65643)
1999 FREIGHTLINER...
John Deere Silage Wagon (A65640)
John Deere Silage...
