Portable generator powering most of house in power outages.
   / Portable generator powering most of house in power outages. #71
I'm not sure what affording it has much to do with anything. I know multi millionairs that don't have standbye systems because they don't think they should have to. Indoor/Outdoor swimming pools and a riding arena, but no permanent standbye generator. I don't get it. To each his own. It's a hobby of mine, and I wouldn't feel covered unless I had four or so Diesel slow running sets of various capacity. I have pretty much assured the power never as much as flickers here anymore!
Yup... and it is sure fun to have my Christmas lights running while the rest of neighborhood is dark:cool2:
   / Portable generator powering most of house in power outages. #72
Another trick I have told homeowners on portable generator wanting to protect hot tubs. A hot tub heat circuit takes up to 5,000 watts for heaters. But a caged water trough heater runs around 250 watts. The cage protects fiberglass and the 250 watts allows it to operate on portable units and prevents freezing tubs in prolonged outages. Just draining tub doesn稚 help as ALL water needs to be purged from pipes and pumps, and most people don稚 do that. Ive seen my share of ice damaged tubs over the years. Last night it was 24f...yeiks. Too early. I haven稚 blown out sprinklers and fountains yet. My fountains are all frozen.
   / Portable generator powering most of house in power outages. #73
Yesterday I sold my Honda EB11000 for $2500. It was bigger than I needed, plus I want the advantages of propane and a dual fuel generator. I am planning to purchase the Champion unit below and connecting it the line that supplies my grill. That line is T'ed after the regulator to the supply line to the house. Primary operation will be from the 500 gal propane tank but it will be good to have the option to use gas if necessary.
Champion Power Equipment 75-Watt Dual Fuel Portable Generator, 1165 at Tractor Supply Co.
My Honda had 275 hours on it after 10 years of use. Our longest outage since I moved here has been just over 2 days and normally power is restored in less than 6 hours. So many times, it is not necessary to power up the generator. I am surprised at how good the power company is.
My needs are different than most. A portable unit is perfect.
   / Portable generator powering most of house in power outages. #74
You definitely traded down! lol
SR
   / Portable generator powering most of house in power outages. #75
I like the immersion heater idea for the hot tub. In a pinch. But I wonder if the heat will make it to the poorly insulated engine house, where the pump and pack is. A small circulation pump would be good, and now it becomes a time consuming project.
   / Portable generator powering most of house in power outages. #76
SR
LOL!!! You are right about that.
But I got burned with bad fuel in my 300 gal storage tank that I had for the gas generator and other toys I used to own. Sold the UTV's and that makes using up fuel even tougher. I have decided to sell the fuel tank as well...should get about $400 for it. So after buying the Champion generator I will be almost $2000 ahead. Keeping enough gas for a long outage is a PITA and I do not want to be schlepping 5 gal jugs of gas around. So much easier and cheaper to depend on propane. I can add another 500 gal propane tank for $1200 but not sure I really need it.
It will be nice not having to fuel the generator when it is sub zero and/or at night. And I will never have a gummed up carburetor.
If the Champion lasts 400 hours, I will get over 10 years out it based on historical usage. And I have an old Generac to back it up.
BTW, wanted to add. After 400 hours, the cost to fuel the Honda would have been $1250 ($2.75/gal); the cost to run the Champion on propane is $400 ($1.39/gal). Almost enough to purchase another new one.
   / Portable generator powering most of house in power outages. #77
I bought gas for $2.17 a few days ago, propane right now is 1.86 and that's if they will let you get the summer price.
You will burn more propane than you would gas too...
SR
   / Portable generator powering most of house in power outages. #78
Either that's new math or I'm not getting something.... :laughing:
400 x $2.75 = $1100
400 X $1.39 = $556
And that's assuming a 1:1 gallon of propane VS gallon of gasoline usage, which probably isn't going to happen, because a gallon of propane contains something like 27% less energy than a gallon of gasoline. You'd need 508 gallons of propane to produce the same energy as 400 gallons of gas.
508 x $1.39 = $706.
At least that's the way I'm seeing the numbers. Please correct me if I'm mistaken. Math isn't my strong suit. :rolleyes:
   / Portable generator powering most of house in power outages. #79
SR
gas 400 x $2.17 = $868
propane 508 x $1.86 = $944.88
   / Portable generator powering most of house in power outages. #80
Your math is good but you have not factored in consumption per hour.
The Honda uses 1.14 gal/hr of gasoline
The Champion uses .73 gal/hr of propane
Also there is a difference in fuel consumption with an 11kw unit vs a 7.5kw unit even at idle. And with propane the Champion is not even at 7.5 kw but 6.75 kw.
I used the consumption rates at 50% load as that seems like a normal load in my conditions.
BTW, my average consumption is about 25 kWh per day....it has never exceeded 45 kWh per day.
I think the smaller unit will easily handle my needs so why pay for capacity I do not need?
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
John Deere 2310 Soil Finisher (A59814)
John Deere 2310...
2014 F-150 STX (A56438)
2014 F-150 STX...
DEUTZ MARATHON...
