Portable generator powering most of house in power outages.
   / Portable generator powering most of house in power outages.
A year in review.
I have used the generator 3 times for outages.... everything has worked as it should. Best money spent. No complaints!
   / Portable generator powering most of house in power outages. #42
there is probably a kit to convert that Champion to natural gas -
then no messing with fuel, and oil will stay much cleaner
   / Portable generator powering most of house in power outages. #43
Thanks.... looks like it came out of the industrial world, and they don't spend on retail advertising.
Shouldn't need a 55gal drum :laughing:, unless I'm planning for back2back apocalpyses..... I'll keep this in mind for future A orders....
You've probably read this earlier.... posting for other folks.......
PRI-D, PRI-G - How It Works @ Survival Unlimited.com
^ Nice #'s on that ASTM D-525-98 gasoline stability test.
Rgds, D
I am wondering how it compares to the stuff Canadian Tire sells.
   / Portable generator powering most of house in power outages. #44
Having learned the hard way that gasoline will be impossible to get for many days after the storm, and when you show up with 55 gal drums the rest of people in line get angry. I made the move to diesel, beside being cheaper to run, its more likely to run. Have had two storms they left us without for 24 days and 15 days. Even groceries were hard to find for awhile. Leaving wasn't a long term option because hotels were filled hundreds of miles away. So you could drive away for the night and sleep in the car, but it would be ruff to get home for days to flooding, power, fuel shortages. So keep a vehicle and spare cans ready for drive out along with lots of cash and guns don't take interstates, chainsaw, chains, tow straps. Both times I have 4 roads out but they were all closed, water, trees. On Third day we cut trees, drag them out of way and forged 12 deep water walking ahead of the 4x4 f350 to keep on the road, traveled for hours to find gas station to take cash, had to wear my handgun and neighbor sat on cab roof with an AR while we filled drums. My current plan is too stay home for upto 2 weeks, got satellite tv and internet if the dish doesn't get a tree on it.
   / Portable generator powering most of house in power outages. #45
Just came across this thread. A few years ago needed emergency power for an oxygen generator for elderly family member. Ended up doing the whole house on the cheap. Bought a slightly used 13K portable generator for $400 of web. Got an outdoor transfer switch and had it wired in by electrician friend and checked by power company. The generator went in a modified plastic garbage can shed on a block foundation. The shed has fixed louvers in one end and in the doors. The other end has a large fan and louvers that open when the fan is on. The battery is kept on trickle charge with a small solar panel on the shed. The muffler meshes well with a vent dryer outlet on the back of the shed and the cable is plugged in and coiled inside the shed, ready to plug into the transfer switch. I test on load a couple of times a year and it always starts right up. Turn off all the circuit breakers and turn on what we need. Can run the furnace fans, microwave, refrigerator, TV and lights, if we only use the ones in the rooms we occupy. Have not tried either of the two central A/C units we have, but I believe the starting load level of the generator will even handle the smaller of the two units. Love the convenience of no extension cords to a portable generator to plug and unplug. First time I used it, a couple of neighbors wanted to know why our house was the only one in our development with the lights on!
The whole thing cost me about $900 and a bit of labor. Have used it twice, but both outages were in terms of hours, not days. Looks good and works good. Videos for similar setups can be found on the net.
   / Portable generator powering most of house in power outages. #46
Good for you Carl!
   / Portable generator powering most of house in power outages. #47
Going back a fair number of years we had a summer outage caused by a 'near tornado', poles down everywhere as well as bunches of trees.
Being at the end of the line we knew we'd be out for many days. Hydro, on the phone, even admitted the long delay.
Called my favorite tool supplier and they advised me they had 25 generators on a truck and en route,
Gave my CC over the phone and picked it up.
Well I purchased a 6000 (electric start) watt genset and never looked back.
At the very least (at that time) the cost was justified just in fridge and freezer contents.
I later installed a manual transfer panel that feeds fridge, freezer, water and sewage pump as well as 2 household circuits.
Just so happens that my main TV is on one of the household circuits so outages are tolerable.
For heat I have an excellent fireplace as well as a slow combustion in the family room downstairs.
Face it, we are talking EMERGENCY here and not all your comforts so I'm good with my 6 KW genset.
Today Cosco generally offer 8/9000 watt gensets for comparable costs (adjusted) that I bought back then.
Actually more serious is communications as during long outages the batteries that power the landline go flat and cellphone coverage is very iffy here.
I have actually seen a telcom truck parked all day just to keep the batteries charged. (yes land lines do need DC power to operate).
LOL, around here I'm referred to as one of the original 'pioneers' as we are on a lake that was initially free 'land grab first come first served'.
Beauty is we are but 1 hour from Montreal but with all the amenities of wild forest waterfront on a pristine spring fed lake at the top of the watershed.
PURE PARADISE!
All sorts of wild life and pure air.
Downside, very slow internet (works but depending on how many download HD films).
All in all I can't complain as for my internet needs it works OK but not everybody agrees with me.
(They are the ones that insist on HD downloads ( and grab all the band with) Heck, I remember when rabbit ears and steel wool was needed to get black and white reception of TV.
HD, **** I don't care what color the commentator's pimple is.
Just let me see the action and hear the words!
   / Portable generator powering most of house in power outages. #48
It's all a big TRAP. Not like people have hard wired lines and the BELL Central Office has HUGE batteries and Generators. I am the only one using the copper that goes in front of my place anymore, and the REMOTE that services my lines some distance out from the CO, has fairly small batteries.
Cell sites, have generator hookups, but in a wide spread outage, there are not many generators to go around, plus the sites may be overloaded.
Long story, short, there may be nothing you can do to ensure communications.
Ham Radio? I'm a Ham, and don't even have suitable gear for that.
   / Portable generator powering most of house in power outages. #49
Our last "long" widespread outage had the cell towers go down, after their batteries ran out. I'm not sure how the land lines stayed up, It looks to me they are on the same poles the power lines are on.
   / Portable generator powering most of house in power outages. #50
both cell towers and land lines were down, The bells brought in small gens running off propane to run the roadside switches. Now the cell towers have propane gens, but they don't regularly run them, so they had startup problems. That's when being on Satellite helped, as long as I had power I had internet and TV.
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
LIGHT TOWER (A56857)
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56438)
2022 Brush Wolf...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
