Gregster613
- Joined
- Apr 19, 2009
- Messages
- 1,046
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi Guys, A little helpful advice requested. This could have gone in the yard & garden spot also, but since I own and operate this machine; I thought I'd put it here.
Here's my dilemma. Scotts 2048 riding lawnmower, 20 hp B&S twin cylinder Intek engine. Two weeks ago I was mowing grass, mower running just fine. Then out of the blue it starts surging terribly, I had to fully choke engine to limp it into the garage. I immediately thought it was fuel related.
I replaced the fuel filter, air filter [regular and pre] , spark plugs, check the valve lash (cold engine, piston at top dead center - plus just a tad more - when both valves closed- as instructions say) valves at a snug .005. During this process I discover my positive cable has corroded through. So I made new Positive and Ground cables also. I thought "Ah haw, I've found my problem." Start it up and it is better some but still slightly surging and now is popping and slightly backfiring through I believe the carburetor.
Next; I disassembled and cleaned carburetor with spray sea-foam and carb cleaner and used air pressure to blow out the jet and passageways. Everything looks clean and good inside. No change in performance. I disassemble and clean it again. No change.
I buy two of those spark checkers that go between the plug wire and the plug. I run it and both seem to be brightly lit. Although the one on the right side of engine (from sitting in seat) "could" be just a "Tad" dimmer than the other. Really hard to tell and could be just an illusion. So now I "probably" can rule out an armature failure?
I'm at a loss here now. Just can't seem to discover any reason it should be popping & sputtering and not running at full strength? I can order a carb repair kit but don't want to just throw $$ at an unknown fix. It now seems like it's an electrical issue, but I just can't seem to discover where.
So I hoped someone here had had a similar issue and had found the cure. Any helpers out there? If so, my sincere thanks!! Greg
