Poly blade
/ Poly blade #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
Trying find if woods makes a polymer cutting edge to go on there blades for snow? Or some kind of good alternative?
Thanks
/ Poly blade #2
Good alternative: lots of people report good luck with a cheap peice of PVC pipe, slit lengthwise, and put on the blade. Works good for gravel drives.
Do you have a gravel drive and want to save the stone?? Or paved/concrete and dont want to scratch it up?
/ Poly blade #4
I had a poly cutting edge and it wore out in 1 season. I think it was ~$100. It definately does not scrape as well. I, too had sensitive surfaces to clean off, but after a season of use, went back to steel.
Have you tried setting up your shoes to help prevent gouging?
/ Poly blade #5
You can find the thick poly cutting edges with a search online. If you want to, buy a horse stall mat from Tractor supply and cut your own rubber cutting edge. They are 40 dollars for a 4x6 sheet. Cut with a jigsaw and drill for mounting bolts.
/ Poly blade #6
a polyurethane cutting edge will be a few hundred bucks depending on your size. If your serious about spending that kind of money i will put you in touch with a guy who will sell and ship them . IMO i would run steel on the blacktop to get the best scraping .. poly is good for gravel and if you run off the drive. the turf damage is less.....
Star (A64557)
Star (A64557)
20ft Jumper Cables (A65583)
20ft Jumper Cables...
TRUCK RAMPS (A64556)
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
Gehl RS6-34 (A64119)
