rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,474
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
I did on mine (double barrel) ... first one was made with rebar ... lasted about 10 years.Did you make a grate for the bottom? Seems to me it would fill with ash fairly quick otherwise.
Just built a new one this last year ... used either 5/8" or 3/4" solid round.
Varies ...How many hours of burn time do you get? How much wood do you put in?
I'm heating a 900 sq. ft. masonry block shop ... it has an 8' insulated drywall ceiling, walls/overhead door are uninsulated.
I run a cheap 20" Wally World floor fan hanging on chains next to mine to circulate the air.
It will keep my shop very comfortable even in the coldest weather, assuming good seasoned wood to burn and a clean stove pipe.
In less than extreme cold (20's, 30's) it will actually run you out of the shop.
If I'm up there working in the winter, I generally keep it in the mid 70's ... I was up there this past week working on a cooler day and it got up to 80 inside the building ...
