Pole Barn advice
/ Pole Barn advice #82
Coming right along... Good work.
/ Pole Barn advice #83
What kind of lights did you hang?
Wedge
/ Pole Barn advice #84
Nothing's easy!:laughing: Good job on the run to the garage. You gave me some ideas on how I'm going to run water as that was still up in the air for me. Nasty having to pull up the deck...I'm in a similar situation but I think I have enough height under it to work the conduit, etc. and don't need to take it apart.
/ Pole Barn advice
One thing I'm glad my dad talked me into was two hydrants, one in, one out. Cost about another hydrant and some extra fittings ($40 or so) for twice the convenience.
/ Pole Barn advice
Wedge
I'll have to get the specs on them tomorrow, I made sure they were good for -20 degrees F so I had no trouble with them starting at night. They were about $50 a piece though.
/ Pole Barn advice #87
Looking real good...
/ Pole Barn advice
Wedge, here is a picture of the box for the lights:
Garage door opener is up:
And an early birthday present to help me out with the rest of it :D
/ Pole Barn advice #89
You will love those new drills. I just bought the whole set with the drill, impact driver, circle saw, sawzall, and the a light. It's cost $575.00 but so far they were worth every penny. I took the circle saw out of the box and put one of the batteries in and used it for two days sawing roof rafters and ceiling joist without ever charging the battery. That new 20v stuff is kick azz I still can't believe how that little saw cuts and how long the batteries last. Oh, and good job on the garage.:laughing:
/ Pole Barn advice #90
What kind of amperage capability did you run from your house to your barn? What size and type of wire did you use?
I want to get electric out to mine soon and am hoping to do a 100 amp circut out there ...
/ Pole Barn advice
100 amp service. The electrician got the wire for the run to the subpanel... all I can tell you was that the run was about 100' and it's a heavy gauge aluminium wire (2 hot, 1 neutral, one ground). I'm not sure about the specs on it other than that.
Inside it's all 12/2 romex.
/ Pole Barn advice #92
Off topic, I got the 3.0 Ah 1/4" impact, 1/2 hammer drill, circular saw, the light and 2 extra batteries about a month ago. The tools sure impress me. I can't get over the saw.
/ Pole Barn advice #93
Yeah you have to be careful with that little impact I was using it to tighten up some 5/16 bolts and that thing would rip them off before you know it. It snapped one off and I was thinking, oh that must have been a stressed out bolt. I went and got a new one out of the box and tried it again and dang if it didn't snap another one off before I could turn lose of the trigger. Those things need an adjustment on them to tame them down a little.:laughing: And yeah those saws are bad azz too.
/ Pole Barn advice
That's why the drill comes with it :cool:
/ Pole Barn advice #95
Thanks ... I will consider the advice despite you being a Bengals fan ... Seems to be the Ohio team to like this year, though. I know I know ... back to pole barns.
/ Pole Barn advice
WHO DEY! I'm not a fair weather fan, I've rooted them on every losing season :thumbsup:
Oh yeah... pole barn... I got the bill for the electrician today. The materials listed for the wire are 115' of 2/2/2/4 wire. Hope this helps.
/ Pole Barn advice
I'm working on getting concrete poured now.
I've decided to go ahead and add some loft space to get some of the junk off the floor...
Setup while working on installing the first couple floor boards...
The rest of them waiting to be lined up and screwed in.
/ Pole Barn advice
Pretty much done with the floor, I need to get some stuff moved up there now.
Floor done, now I was lining up 2x4s on the edge to keep things from sliding off
View from the bottom
/ Pole Barn advice #99
If I'm seeing right, ~10' long 2x4's spaced 4' apart isn't overly strong - Careful not overload! :thumbsup:
/ Pole Barn advice
It isn't, but thank you.
Lincoln Welder (A62613)
Lincoln Welder...
27x32 CIH Rim (A65640)
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
Pallet Racking Uprights (A62613)
Pallet Racking...
