Snow Attachments Plowing snow with rear blade
/ Plowing snow with rear blade #1
Erallain
I have a Woods rear blade on a 3030. Can push the snow or or should I drag it behind the tractor. If I push it doesn't dig in as bad because of the curve in the blade. Simple question..just don't need to bust anything. Thanks.
/ Plowing snow with rear blade #2
Welcome to the forum.
What is under the snow? asphalt, gravel, frozen ?
Where are you located - generally?
Might look at the threads that discuss putting a plastic pipe along the edge of the blade. Less cutting in to "things" and I'd think less wear and tear on the rear blade.
/ Plowing snow with rear blade #3
For me it depends on the road surface and amount of snow. First, I always try to pull instead of push - don't have to look back as much. On the gravel and with light snow, I usually turn the blade around backwards, angle the blade and drive forward. I try to skim the surface so I don't remove my gravel. This works if the snow is not very deep and works better for a heavier blade than a light blade. If I can't dig down deep enough due to heavy snow, ice or packed snow, I will turn the blade forward, angle and use the blade driving forward. When turned forward, I try to use just enough weight on the blade to do the job of moving the snow but not my gravel. Your tractor will have more traction driving forward than in reverse.
I drive in reverse, with the blade turned backwards, if I want the push the snow farther from the edge of the road or if I want to push into piles. If you push backwards too hard or hit a solid obstruction, you can run the risk of bending lift arms or breaking the pins/lift arm attachment to the tractor. That can be a very $$$ repair. If driving in reverse and with blade turned backwards, the blade will want to dig deeper than needed and requires more skill when used in that method.
On a hard surface such as concrete or asphalt, I leave the blade forward, angled and just drive forward.
After 1-2 snows, you will have discovered what works best for your blade and tractor. More than one way to get the same job done. Some methods work better than others depending on equipment and amount of snow. Now go have fun in the snow!
It's gravel. 1 3/4" minus in some places. I was not aware I could reverse the blade. But you guys did answer my question....not a good idea pushing with the blade. Thanks.
/ Plowing snow with rear blade #5
I drive over the snow for the initial passes if it's more then 5" or so deep. The back blade is set so it's an inch or so about the surface. That let's me use both the loader bucket and blade.
For the final passes and clean up, I'll reverse and push the snow with the blade all the way down.
My reasoning is this: The 3PH is really designed to pull, not push, so the stresses are reduced for the heavier load. Unfortunately, my old blade is not reversable nor can I rotate it enough so the convex side faces the direction oftravel when I'm driving forward.
/ Plowing snow with rear blade #6
My blade allows a swivel so that I can pull the blade facing either direction.
No need to ever go backwards.
/ Plowing snow with rear blade #7
I pushed mine for years, seemed easier, untill I added a front plow.
/ Plowing snow with rear blade #8
I mostly pull forward and only push back in a couple of spots where necessary. Like RoyJackson, I will make a first pass with the blade raised some if the snow is deep. I also straddle the banks with blade slightly raised to push the bank back further to reduce drifting.
You can change the 'bit' of the blade by adjusting the length of the top link. When going forward, shorting the link will lessen the bit.
/ Plowing snow with rear blade #9
If the snow's not too deep, I drive over it and pull. If it's more than 4 inches I turn it around and push.
Actually I looked on Woods web site and I have the Standard-Duty Rear Blades - RB Series. Not sure I can flip mine around. May try the PVC pipe.
I'm going to adjust the 'bit' of the blade as you were saying Stonehaller. I adjusted it in the other direction landscaping last spring.
/ Plowing snow with rear blade #12
You can push, but you risk bending a swing arm designed more for tension than compression. (Yeah, I push sometimes...)
Can you rotate the blad 180 degrees and pull it with the convex side facing forward? This technique has been discussed in other threads.
/ Plowing snow with rear blade #14
I have a 7ft woods blade (RB84 I think) - I have been using skid shoes to keep the blade about 3/4"-1" above my gravel drive and pull forward. This has worked well including the 18" snowfall with the december blizzard. I angle the blade to the side and also change the bite with the top link as suggested. I tried the PVC pipe trick also and shattered a piece the first time out - too brittle in real cold weather. Some people have suggested using ABS as it is less brittle, but I couldn't find a short piece at the big box stores. My blade does also reverse so you can pull it forward with the convex side forward to also limit digging into the gravel.
