Plastic welding
/ Plastic welding #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Did my first plastic welding repair today. Sorry no pics. Being my first time I didn't think it would be picture worthy... but I'm pleased with the results.
I watch some videos and purchased a higher end iron from Amazon > Amazon.com
I saw a video showing a guy melting paperclip into the plastic across the crack - I did that. Followed instruction to V the crack, then melted the clips in, and then fill and smooth.
The subject was a large irrigation box my friend gave me ( retail $97 ) But it was cracked from the bottom up but no yet in half. I now have confidence I can fix the 4k gallon poly tank I bought this thing for.
We have so much plastic in our daily lives. Good to know it can be repaired.
/ Plastic welding #3
Since it's a plastic tank, plastic weld is the first layer. Next use Marine grade fiberglass gel coat over it. This way it will not separate when the tank is filled and becomes weight loaded on the tank walls.
/ Plastic welding #5
Those melt-in repairs work awesome. I've been using one for a few years now. A guy I know threw out a DeWalt ¼" hex drive impact because he dropped it from a high ladder onto concrete and the base where the battery slides in cracked almost completely off. I saw it in the trash and stuck a battery on it and it still worked fine otherwise. Brought it home and ground out around the crack, melted in stainless steel window screen and filled with plastic. My son is still using it as his first impact 2 years later.
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Refurbished KBH Tender Trailer (A63689)
Refurbished KBH...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
