plasma cutter tips
/ plasma cutter tips #1
txbovine
I bought a Thermal Dyn. CutSkill mod c35 plasma cutter. It has its own air source. Well my problem is that the tips don't last very long. I'm trying to figure out ifs my tech. or the machine , for example i can cut 8 inch of 1/4in mild steel and than the copper tip is cratered . Hole starts out at .040 and ends up the size of a match head whats the deal. thanks for all advice.:confused::mad:
/ plasma cutter tips #2
I own a firepower 35 and it had the same problem. The unit had two issues, the ground strap was causing the tip to burn up so I replaced the ground wire and that helped with my tip issue. Oh, I had another problem; the power relay was worn and caused a loss of power at the tip, after replacing the relay the unit works like new. Back to cutting 1/8in :)
/ plasma cutter tips #3
You must have very dry air. That little filter may not be up to doing its job. Water/oil will cause those tips to wear prematurely.
Maybe try another air source if that is possible.
/ plasma cutter tips #4
I have had similar problems with plasma cutters - then I found that I had the air pressure way way too high - check the regulator?
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
1993 International 4900 Ram Rodder Combination Sewer Jetter Vacuum Truck (A64194)
1993 International...
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
Conveyor Belt (A64194)
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
