Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,501
GAPROPERTY,
How does that HLA1000 feel on the 3000 series Kubota? 20" height and 400 lbs I was wondering if it felt like you can easily bend it.
Does the HLA have Vertical Float? Using a snowplow on a loader is tough as it is hard to find the correct angle every time you drop the blade to the ground. Lots of vertical float is important to help keep the stones on the driveway.
The plow feels light and trips to easy. It was the only one at the dealership. About 4 hours there was a used 2000 for sale. I might be wishing I went and got it but it also required a third function.
As for finding the right angle I have a metal indicator that shows when the plow is level. I go slow and carefully watch when the plow starts to expose the rock the tilt it back a bit. When the ground was frozen with hard pack snow the float on my loader worked very well.
   / Pictures of your snow weapons #4,502
I just hooked up the pto pump and rear hydraulic tanks las5 weekend. Ran hoses up front. I have not hooked up chains yet,as ground is still too soft. but snow had started. There predicting 12 inches thru tomorrow. So far only 2. Looks like winter had finally come.
   / Pictures of your snow weapons #4,503
gaproperty
Here is a video of my snow weapon and beautiful wintery scenery along my snow route.
Nice setup. :thumbsup:
Now that's what I call enjoying plowing snow...thanks for sharing. :)
I find it a type of art to do a nice job. Very relaxing except for dealing with some customers.
   / Pictures of your snow weapons #4,504
Here they are
2018 Cub Cadet Challenger 750 side X side with 72" Denali snow plow with Hydro turn ( angler)
2014 Kioti 30 HST with 66" Front Mount Snowblower with hydraulic shute and heated cab.
Kioti: you have Front AUX hydraulics or are you using a Pump off the rear PTO?
If you have Front Aux hydraulic connectors, How many GPM does it pump for the Blower to run well?
   / Pictures of your snow weapons #4,505
   / Pictures of your snow weapons #4,506
Thanks for the honest feedback. Oh yes, most AG tractors have that Bar that indicates 'level'. I don't have that on my Backhoe. In all honesty, you are probably better off with the 'light' blade. I have a 1000lb plow and I can almost never let the feet rest on the ground or it will dig the stones. I made much larger feet and it's still a problem. The weight of the plow forces me to constantly lift and lower the Loader arms as my driveway has enough ups and downs to keep me busy. I am jealous of my neighbor who runs a small pickup truck with a 'toy" plow. most of the season he zips around with that light plow just floating on top and leaving the stones in place.
I love the big plow when we get the 40+ inch snowfalls. Then I go and help out small pickup guy. My plow is 33" tall.
Thanks again for sharing
   / Pictures of your snow weapons #4,507
I do not have a pump off the rear PTO. Blower runs off Mid PTO at 12.8 GPM. The blower throws snow over 50 feet if that means anything and engine revving at 2400 rpm if I am not mistaken. So my 30 hp tractor handles it pretty darn good.
Here is an old pics of it in action before I had my heated cab installed also never had to use chains.
   / Pictures of your snow weapons #4,508
Can't afford a snowblower this year; so I'll be getting plenty of loader experience. But at least I finally got the Tractor
"You don't need a tractor", said the wife; until I made her help me shovel the snowpack that falls off the garage.
   / Pictures of your snow weapons #4,511
   / Pictures of your snow weapons #4,512
Thanks for the advise. We got slammed with snow/rain/ice so the driveway is a mess. It'll definitely be a learning experience so hopefully the wife doesn't record the first snowfall I use it on... but if it doesn't snow again this year in Maine it's my fault, cause we finally pulled the trigger on a tractor.
   / Pictures of your snow weapons #4,514
12 inches! Man, I would love to tuck into that with my blower. Unfortunately, we haven’t had much yet up here in the Great White North, but it’s coming, and the Christmas lights are up now. (Got a bunch of them newfangled LED lights.)
   / Pictures of your snow weapons #4,515
Tekkwolf
Funny/strange how that works. ;)
   / Pictures of your snow weapons #4,517
Welcome to the Forum. Not sure how much land you have or how rural the area is but you will find so many uses for the tractor and bucket after you own one.
Looking at your picture, looks like you have a lot of hydraulic lines there. Do you have auxilary hydraulic fittings up front?
P.S. don't be shy in getting your wife behind the wheel, she will enjoy it as well. see pics different tractors... same wife
   / Pictures of your snow weapons #4,519
   / Pictures of your snow weapons #4,520
Took the loader off after cleaning the garage enough to have access to where I wanted to put it. I've tried and tried to have it on wheels, and can't seem to figure it out. Last year I drug it by hand sideways about 8', and that SUCKED. So I figured out how to put it where I want to from the other end of the garage. MUCH nicer...
Then I put the stupid subframe on and the blower on. I hate that subframe.
I still have to put on the chains (which I also hate doing) & put down my floor-protecting mats.
Just curious, wouldn't these harbor freight dollys work? I have four and a heavy car rolls easily on them. They're not expensive and hold 1000# each.image_21404.jpeg
2016 JLG T350 TOWABLE BOOM LIFT (A60429)
2016 JLG T350...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A60432)
ANTHONY CARTS...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
