Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,501
GAPROPERTY,
How does that HLA1000 feel on the 3000 series Kubota? 20" height and 400 lbs I was wondering if it felt like you can easily bend it.
Does the HLA have Vertical Float? Using a snowplow on a loader is tough as it is hard to find the correct angle every time you drop the blade to the ground. Lots of vertical float is important to help keep the stones on the driveway.
The plow feels light and trips to easy. It was the only one at the dealership. About 4 hours there was a used 2000 for sale. I might be wishing I went and got it but it also required a third function.
As for finding the right angle I have a metal indicator that shows when the plow is level. I go slow and carefully watch when the plow starts to expose the rock the tilt it back a bit. When the ground was frozen with hard pack snow the float on my loader worked very well.
   / Pictures of your snow weapons #4,502
I just hooked up the pto pump and rear hydraulic tanks las5 weekend. Ran hoses up front. I have not hooked up chains yet,as ground is still too soft. but snow had started. There predicting 12 inches thru tomorrow. So far only 2. Looks like winter had finally come.
   / Pictures of your snow weapons #4,503
gaproperty
Here is a video of my snow weapon and beautiful wintery scenery along my snow route.
Nice setup. :thumbsup:
Now that's what I call enjoying plowing snow...thanks for sharing. :)
I find it a type of art to do a nice job. Very relaxing except for dealing with some customers.
   / Pictures of your snow weapons #4,504
Here they are
2018 Cub Cadet Challenger 750 side X side with 72" Denali snow plow with Hydro turn ( angler)
2014 Kioti 30 HST with 66" Front Mount Snowblower with hydraulic shute and heated cab.
Kioti: you have Front AUX hydraulics or are you using a Pump off the rear PTO?
If you have Front Aux hydraulic connectors, How many GPM does it pump for the Blower to run well?
   / Pictures of your snow weapons #4,505
   / Pictures of your snow weapons #4,506
Thanks for the honest feedback. Oh yes, most AG tractors have that Bar that indicates 'level'. I don't have that on my Backhoe. In all honesty, you are probably better off with the 'light' blade. I have a 1000lb plow and I can almost never let the feet rest on the ground or it will dig the stones. I made much larger feet and it's still a problem. The weight of the plow forces me to constantly lift and lower the Loader arms as my driveway has enough ups and downs to keep me busy. I am jealous of my neighbor who runs a small pickup truck with a 'toy" plow. most of the season he zips around with that light plow just floating on top and leaving the stones in place.
I love the big plow when we get the 40+ inch snowfalls. Then I go and help out small pickup guy. My plow is 33" tall.
Thanks again for sharing
   / Pictures of your snow weapons #4,507
I do not have a pump off the rear PTO. Blower runs off Mid PTO at 12.8 GPM. The blower throws snow over 50 feet if that means anything and engine revving at 2400 rpm if I am not mistaken. So my 30 hp tractor handles it pretty darn good.
Here is an old pics of it in action before I had my heated cab installed also never had to use chains.
   / Pictures of your snow weapons #4,508
Can't afford a snowblower this year; so I'll be getting plenty of loader experience. But at least I finally got the Tractor
"You don't need a tractor", said the wife; until I made her help me shovel the snowpack that falls off the garage.
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
1762 (A58375)
1762 (A58375)
Hays LT1 Tender (A56438)
Hays LT1 Tender...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2013 Ditch Witch XT855 Tracked Loader (A56436)
2013 Ditch Witch...
Westendorf 400 bu Gravity Wagon (A59814)
Westendorf 400 bu...
