Picked up a new drill press
/ Picked up a new drill press
That's EXACTLY what i was thinking... I kinda want... but it kinda terrifies me that it would kill me too! ;)
Keep it low. The bucket will stop you from rolling forward. And the weight in the bucket kept low will stop it from going backwards. I had a couple moments where I got close to going over backwards, and it was never when I was using it properly.
/ Picked up a new drill press #23
I'd be worried about my arms being ripped off by the hydraulics. Never operated one, guess if you need hands on the controls, shouldn't be waving to someone while raising or lowering a load. FOCUS
/ Picked up a new drill press #24
Neat video Jay. Must say that with the way you think things out I'd expect you to have some sort of hoop or tunnel to slide the pipe through to stop that annoying lifting from the drill bit:)
EDIT TO ADD: If you get that lathe, I'll drive down and help you unload it.
Yeah, hands are pretty busy, and if you keep it low, it never comes up to your arms.
I thought about making a hoop for it, but I just pushed through and I finished in half the time i figured it would take me to make one.
if you need anything or advice.
Old Woodworking Machines - Index page
old wood and metal working machinery
Thank you. I am really curious how old it really is. There's a feature that I'm fairly certain is an automatic up/down for the press, but the shaft is stuck. I haven't had a chance to take it apart yet though. I need more time.
/ Picked up a new drill press #27
I’d at minimum weld 2 post on the front to protect you from swinging a load into yourself. Maybe if you strictly moved dirt it wouldn’t be awful but that thing is a death trap. It couldn’t be hard to find a roll cage from a forklift or bobcat.
/ Picked up a new drill press #28
Everything freshly lubed, belts adjusted, table sanded and cleaned, and it's off to the races!
Short video:
https://i.imgur.com/48ETPyQ.mp4
Bobcat is a 1970 M600 I bought for $2500 last year and has been absolute invaluable in my garage build: https://i.imgur.com/CRR8SML.mp4
That drill press is sweet, nice work getting it all ready to rock.
While I agree that the Bobcat is a deathtrap, I absolutely love it. $2500 for the amount of work that it can help you perform is well worth it!
/ Picked up a new drill press #30
I have to wonder if the electric motor wasn't an after-thought and it was originally designed to be run by a line shaft. It would give reason for the foot pedal to disengage the drive system without turning off the motor, which is what I suspect it does, which would be necessary if it was line shaft driven. They were popular in Massachusetts, and this thing was made there.
I thought it might have been a line shaft machine that was later converted to electric. I took some better pictures today. This thing seems to have come with all the bells and whistles. The plate goes up and down with a half inch drive ratchet and is very solidly mounted. I already lost one drill bit that went down the hole and there's no real easy way to access the inside.
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
UNUSED FUTURE 16" HD MINI EXCAVATOR AUGER (A60432)
UNUSED FUTURE 16"...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Deere 350G LC (A53317)
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
