Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,730
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I wanted to install a new valve to control my grapple and get it off of the rear remotes so I can use them for TNT. I wanted the valve control to be near my FEL lever. Last Nov teg posted a very nice discription of a similar project he did. I stole alot of his ideas. THANKS teg. This is a link to his post
http://www.tractorbynet.com/forums/...7948-instructions-add-extra-spools-l2800.html
I started by buying a single spool DA 8 gpm Prince valve fropm Surplus Center.
Prince # MB11B5C1 DA.
I built a mounting plate for the valve from a piece of 5 1/2" X 6" 1/4" plate.
I drilled and tapped 3 holes for 3 3/8" mounting studs. Jam nutted and welded them.
Drilled 3 5/16" holes to mount the valve, and one hole in the corner for a heavy sheet metal screw to attach to the orange cover. I am going to mount the valve and plate on the FEL linkage cover. Photos: Linkage Cover, Cover Removed, Base Plate.
