Photos of Third Function Valve Project
   / Photos of Third Function Valve Project #11
Thanks.
That makes sense but I have no clue how to contact a moderator :confused:
The info must be here somewhere but I haven't found it yet.
gg
Click the red triangle that is under your username...
   / Photos of Third Function Valve Project #12
I don't know... it is both hydraulics and you are building it yourself. We can move it for you if you like, or leave it here. Just let us know by pushing the little report post button again and dropping us another note. Your choice. ;)
Nice job, by the way. :thumbsup:
   / Photos of Third Function Valve Project #13
There you go. :thumbsup:
I moved it to hydraulics per your request and left a redirect in the original forum that will expire in a month. That way anyone that was following the thread will be able to find it for the next 30 days. ;)
   / Photos of Third Function Valve Project #14
Teg, I have a question regarding your well detailed valve install. Could your 3 spool install be reconfigured with a elec/hyd valve for grapple? I would love to match your design.Just change to, TnT for the back and switch on joystick for front??? maybe a layout of (lever-elec- lever) stack on top of housing like yours
Neal
   / Photos of Third Function Valve Project #15
Teg, I have a question regarding your well detailed valve install. Could your 3 spool install be reconfigured with a elec/hyd valve for grapple?...
Neal, yes (if I understand correctly) you can. The only reason I did not use the elec./hyd valve was cost for just one valve... I don't have a problem using the grapple as it is setup now. ...and I can't see a need for the elec./hyd switch (i.e. what does it do better???)
I would not buy the Needle Valve, while the are nice, I can feather the valve easy enough.
Trim the apple trees, cleanup was quick and easy. My "birds nest"... you can see I cut 8.25" off my FEL joystick... makes it extremely responsive (I'm still trying to figure out if that's a good thing or not...)
   / Photos of Third Function Valve Project #16
Thanks Teg. I will rethink the elec/hyd. I guess its bells and whistles when it comes down to it. After all, how many times do you actually open and close the grapple while moving curl/raise all at once? Could you give more info on what and where on the grapple purchase??? Also $. Thanks
Sorry for stealing the thread. BTW, thank you Gordon for your nice write up on your project. Very helpful for me as I have the same set up (orange metal cover) you do.
Neal
   / Photos of Third Function Valve Project #17
Teg, forgot to ask; is the set up under your step with the filter factory? I would like to put a filter on mine as it only has the strainer. Also is that block where you get power beyond or at valve? I have PB from loader valve to BH now. Sorry, didnt go back through all your photos.
   / Photos of Third Function Valve Project #18
...After all, how many times do you actually open and close the grapple while moving curl/raise all at once?
I'm not in a rush to get things done so doing one thing at a time isn't a problem. I take small bites and make a larger pile than take a bite into the large pile... usually getting most of it.
I bought the grapple used from TBN member Westbrooklawn for $350 - I always liked the style of the WR Long grapple vs. the Thumb (or the like). It comes with the reinforced top bar that bolts to the sides of the bucket.
I didn't make any changes under the step area, it's factory. Power Beyond is part of the valve, in both the FEL and my added spools.
Now back to Gordon Gould's thread :D ;)
teg I like your cut off FEL lever. Puts everything close.
I like the idea of a fully hydraulic control to give you a better "feel" and feathering ability. In real life I don't know how important that actually is, but I like it. Also the fully hydraulic control was simpler and cheaper for me to install.
I finished my lever arm. The grapple control is always within reach now. It moves left to right with my FEL lever as I dump and curl. It is much better than where it was down by my rear end on the rear remote control.
We had some lousy weather so I sat down and figured out what I needed for hydraulic fittings. I used #8 (1/2") fittings and QDs with 3/8" hose to be consistant with the original equipment. I ordered them from DiscountHydraulicHose.com.
It looks like my total cost for the Third Function Valve installation will be just under $250. Here is how it breaks down.
Parts S/H
Single Spool Valve Surplus Center $89.95 $12.98
5 1/2" X 6" X 1/4" Plate Walbridge Welding $5.00
Includes welding nuts
18" length 1/2" rod Walbridge Welding $6.00
Includes welding bushing
Knob for lever arm Messicks $15.37 $13.61
Fittings Discount Hydraulic Hose $55.77 $16.09
3 short 3/8" hoses w/ jic 8F NAPA $30.00 (est.)
$202.09 $42.68
I hope someone finds some of this info useful.
gg
1629 (A57192)
1629 (A57192)
1000000 (A47477)
1000000 (A47477)
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
