PHD on 790
/ PHD on 790 #1
edgaines
South Carolina
JD790
I got a PHD for the 790, then found that the 3PH wouldn't go high enough to get it off the ground. I ordered another adjustable link to replace the fixed "down link" on the left side of the 3PH, to get it higher. I realize I will have to drill the hole, then, with the auger down, adjust out the links to get to the right depth. Anyone else have this situation?? /forums/images/graemlins/tongue.gif
/ PHD on 790
It only has 1 "extra" hole in it, and it raises only about 1".
The price of the adjustable is $179, but I gues I gonna have to bite the bullet anyhow.
/ PHD on 790 #4
Can you add plates like in this picture?
/ PHD on 790 #5
Ed,
Do you have an extra long auger bit? I have a PHD and it is probably 6 to 8 inches off the ground when raised all the way up?
/ PHD on 790
I got it fixed, and working by drilling holes in the down link forks from the lift arms 1.5 inches up from original. Works great now.
Thanks for all the suggestions.
/ PHD on 790 #7
Are you sure your drive arm isn't just too long? Mine was and I had to cut it. I have a 790 and greenline PHD.
Buck
