PHD on 790
/ PHD on 790 #1
edgaines
South Carolina
JD790
I got a PHD for the 790, then found that the 3PH wouldn't go high enough to get it off the ground. I ordered another adjustable link to replace the fixed "down link" on the left side of the 3PH, to get it higher. I realize I will have to drill the hole, then, with the auger down, adjust out the links to get to the right depth. Anyone else have this situation?? /forums/images/graemlins/tongue.gif
/ PHD on 790
It only has 1 "extra" hole in it, and it raises only about 1".
The price of the adjustable is $179, but I gues I gonna have to bite the bullet anyhow.
/ PHD on 790 #4
Can you add plates like in this picture?
/ PHD on 790 #5
Ed,
Do you have an extra long auger bit? I have a PHD and it is probably 6 to 8 inches off the ground when raised all the way up?
/ PHD on 790
I got it fixed, and working by drilling holes in the down link forks from the lift arms 1.5 inches up from original. Works great now.
Thanks for all the suggestions.
/ PHD on 790 #7
Are you sure your drive arm isn't just too long? Mine was and I had to cut it. I have a 790 and greenline PHD.
Buck
2019 Yanmar ViO35 Midi Excavator (A66734)
2019 Yanmar ViO35...
2100 GAL WATER TANK (A68842)
2100 GAL WATER...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
Depth Band wheel, Scapers (A68191)
Depth Band wheel...
2005 Honda Pilot AWD SUV (A66738)
2005 Honda Pilot...
