Posthole Digger PHD for JD2520
/ PHD for JD2520 #1
pkav32
Massachusetts
john deere 2520
Does anyone have an opinion on a PHD for a 3PH. I have read in the treads that they either work well, or they are a waste of money. I have to put in about 100 fence post at my new house and I was planning on using a PHD with my JD 2520. I live in Mass and with the amount of rocks I could get I am skeptical of the results. Either way 100 holes by hand will not be much fun. I could also use opinions on which brand. I was looking at the Frontier or Land Pride. I have seen cheaper PHDs, but I always feel you get what you pay for.
Thanks,
Paul
/ PHD for JD2520 #2
I have lived in Massachusetts most of my life. I have put in miles of fence most of it by hand. I own a Land Pride PHD and would not be without it. It is a PHD 15 with a 9 inch auger. You get what you pay for is all I can say.There are many who insist on a 12 inch but I'm my opinion a 9 works best. stone is something to deal with no matter how you dig your holes, clay is a bigger problem for a PHD than stone. I would definitely purchase a PHD if it were me, It might help if you gave us a little background. If you are putting up livestock enclosures the is no question what to do. Anyway welcome to TBN
/ PHD for JD2520 #3
I had a mid-level Bush Hog PHD and that was a stupid purchase that I made. Not the brand; but the PHD. We have claycrete where I live and I got the auger stuck at the gearbox. I managed to rock the thing loose; but if I ever get the foolish notion to get a PHD again, it will be hydraulically powered unit so I can reverse it if it gets stuck, and it won't be a 3 point hitch type either as they are like wrestling with an octopus to connect and disconnect.
Go rent a skid steer with a hydraulically powered auger and go to town digging holes.
I traded my PHD in as a down payment on a riding mower.
/ PHD for JD2520 #4
I own a Speeco, from TSC. It is about the lowest cost one there is. And it works great. As far as rocks, they come in all sizes. If you are drilling a small hole (9 inch for instance), and you hit a four inch rock, you are about screwed and must bust the rock out of the way with a bar or something. BUT if you are drilling a bigger hole (12 or 14 inches), that same four inch rock will come out with the dirt. Northern sells a larger bit (14, I think) that fits the speeco, even though Speeco themselves sell only 12 inch at the biggest.
A great idea someone here on TBN had, I still need to copy, is to weld on a segment of 2 inch water pipe horizontally across the bit down-tube, like at the top end of the flighting, or higher. this way when you hit a rock or auger under a root, you can stick a shovel handle thru the pipe segment (with tractor OFFF!!!) and turn the drill backwards. Sure beats disconnecting it from the powerhead and pipe wrenching on it.
Ideally you would have power revers on the PTO, to back out of bad situations. Hydraulic would also help a lot, variable, and reverse. There are some PHD that are loader-bucket mount ones, hydraulic powered, etc. Nice, but expensive.
/ PHD for JD2520 #5
Maybe if you would have had your phd on a stand you would not have fought it so much. By selling your phd you now have taken away the convenience of being able to go and drill just a few holes when needed. My guess is that in your situation you don't need that convenience. I have found that renting equipment is inconvenient and costly. Renting can be a real problem if needed on spur of the moment type of conditions. We each do what works best for us. Oh, unless I'm having a bad day, I can have my phd hooked up and ready to use in about 5 minutes.;)
/ PHD for JD2520
Thanks for your input guys. I am putting in a 4 ft high post and rail fence ( 6" posts). I think that I would like to get a phd, but the thought of getting it stuck in the ground seems to be very frustrating. I also find it frustrating when I bought the tractor for these jobs, and I am told to rent. I will have a tough time explaining it to my wife why we just spent 16K and still rented equiptment. I do hope that building my house on a christmas tree farm will mean that it is pretty good soil. The more opinions the better. Thanks again guys.
/ PHD for JD2520 #7
buy the phd, for 4ft fence you only need to go 2 ft down. control the dig with the tractor lift and it won't get stuck.
/ PHD for JD2520
Thanks JiminGa,
I like definitive answers. What size auger do you recomend. I was thinking about a 9" like Timber recommended. Jimgerkgen mentioneed smaller augers jam up with rocks that a 12" auger will dig up, maybe it is wiser to go bigger. Of course this is a motto here at tbn, always bigger when you can.
thanks again.
/ PHD for JD2520 #9
I have yet to have to back my PHD out of a hole, not that it can't happen but you do have to pay attention to what your doing. I also recommend an assortment of bars and a clamshell. Every hole is going to be different you might sing 10 holes in a 1/2 hour and spend 2 hours on 1. Welcome to earth man. I use my PHD for post holes and sauna tubes as well as loosening up the soil around stumps I want to dig out.
/ PHD for JD2520 #10
I have a bush hog phd. Works great. Never got stuck. Went right through that power line too! But they are a bear to put on and off. I partially disassemble mine to make it lighter. If you get one, either build a stand or buy one.
Not sure about your deere. But, if it's not a full cat 1 hitch, some phd won't fit. Your JD dealer would probably advise you best.
/ PHD for JD2520 #11
Now this might not work for you, although I don't know why not, but while you are using a phd raise the auger up about 6" every 6" it digs down after it is down about 12". Does this make sense? Anyway do this until you have reached the depth that you want. I do this often and like some of the other posters, have never had an auger stuck.;)
One other thing, a lot of guys have good luck with the inexpensive phds, but you do get what you pay for and if you want as few problems as possible spend the $$$$ for a better phd and auger.
Just my experience, hope that it helps you.:)
/ PHD for JD2520 #12
My feeling on implements is if it has a gear box buy a top brand, If it is a non mechanical buy anything that fits the bill.My PHD is one of my most important implements. Not that I use it all the time but when I need it it will spend weeks on my tractor. there is a way to use it and every hole is different, you have got to clear the hole as you drill. If you sink the drill and let the hole fill in on top of it what do you think is going to happen. The other thing about storing and mounting is no more hassle than any other implement. In fact I find it one of the easiest to store and mount. It takes up no room at all in my shop.
/ PHD for JD2520 #13
I bought Bush Hog's optional parking stands for it, which placed the 3PH connections at the right height for hook up. I just found it a pain to connect, use and disconnect as I had to remove my quick hitch, then the top link, then fight with the thing to hook it up. Of course the projects I bought it for didn't materialize as I had expected. In my case, renting would have been far cheaper than buying the PHD. I had a 12" auger by the way. Anyway I'm glad it's gone.
/ PHD for JD2520
Thanks for everyones help. I think that I am going to go with either a land pride or a frontier PHD. will just take it slow.
/ PHD for JD2520
Does anyone recall what they paid for thier Land Pride PHD.
/ PHD for JD2520 #16
pkav32 said:
Thanks JiminGa,
thanks again.
I would think a 9" hole would be hard to get a packing stick in, I like 12" better, also a larger one may be of use if your mrs. has lots of potted plants for you to install.
/ PHD for JD2520 #17
I love the 9 inch but a 12 will be OK too. I have a lot of experience digging post holes so i am good at locating them and dealing with obstructions. My reasons for a 9 are I like hole integrity. If I need to open it that is very easy. Much is personal as what you want to work with. My feeling is the bigger the auger the bigger chance of caching something on the way down
/ PHD for JD2520 #18
Land Pride PD35 $1495
Land Pride augers 6", 9", 12", 18", and a 24" tree auger $1676
Land Pride hydraulic down pressure kit $500
/ PHD for JD2520
Has anyone used a phd with the iMatch system, or Pat's easy change. I planned on getting the iMatch. Just curious.
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2015 INTERNATIONAL PROSTAR+ (A67714)
2015 INTERNATIONAL...
PT 5' Disc Offset Harrow (A64912)
PT 5' Disc Offset...
WACKER NEUSON LTN6 LIGHT TOWER (A65056)
WACKER NEUSON LTN6...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
