Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #501
rbtjr- Thanks very much for the information. Due to other issues/problems, I have not had an opportunity to attach Pat's easy change yet. I am hoping to be able to work on it tomorrow. I meant to order the stabilizer bar with it, but forgot to do so. I may have to order it separately. Thanks again. Bob
   / Pat's Easy Change System - Order Online! #502
I finally got time to install the PED system. BUT.....ran into a serious problem- I have a Kubota B2910 which is a Category 1 tractor. As with others, the lift bar (middle bar) was then too short. I went to my Kubota and got a longer one. But, it is too wide to fit in the slot for the pin. And, it is a Category 1 bar. I tried one at Tractor Supply and had the same problem. Did anyone else have this problem?
   / Pat's Easy Change System - Order Online! #503
The correct term is "top link" instead of "middle bar".
   / Pat's Easy Change System - Order Online! #504
TSC has two lengths of cat 1 toplinks. You need to get the longer one. That is what I had to do...The shorter one
was about the same as the OEM on my Kioti.
   / Pat's Easy Change System - Order Online! #505
Another TBN Member told me where to order a top hitch adaptor. I ordered one. Go to Agrisupply.com and search for item # 61369. It is only $17.49 and should solve the problem.
   / Pat's Easy Change System - Order Online! #506
So,Bob19, just to make sure after reading your post for the adaptor, this is what you used, to compensate for the shortness of the stock OEM top link, after you installed Pat's easychange system?
thanks
   / Pat's Easy Change System - Order Online! #507
thanks
   / Pat's Easy Change System - Order Online! #508
Ahh. Installed my Pat's system and alas, gotta get a longer top link assembly and be done with it. I am glad I ordered the spreader bar with the system.
   / Pat's Easy Change System - Order Online! #509
mine was a little too wide so on the grind wheel it went to shave it off a little on both sides and walah it fits perfectly. sometimes you just gotta modify.. :D
   / Pat's Easy Change System - Order Online! #510
Hi,
I am thinking about getting a Pat's for my LS G3038H tractor. Would I need a Cat 1 for this?
Thanks,
.Eric
New/Unused SD Lanch SDLL50 Mini Skid Steer (A57453)
New/Unused SD...
Electric Concrete Mixer (A57453)
Electric Concrete...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
8ft Teakwood Live Edge Slab Table (A57454)
8ft Teakwood Live...
7ft Workbench (A57454)
