Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #491
I thought about adding a hydraulic top link to use along with Pat's ECS but my son talked me out of it. In our case it would just be harder to hook up the top link due to extra weight and hoses. He said it would just be money wasted since we do not need to adjust the top link except when we first hitch to another piece of equipment.
We use the Cat 2 ECS system on the 265 MF (60 HP?) with a 1000 pound 8' Bushhog Brand box blade and a super heavy duty 7' bush hog type mower and so far even with some abuse the Pat's system has held up well and reduces accident risks greatly when changing implements.
   / Pat's Easy Change System - Order Online! #492
Thanks. Good point about the hydraulic top link. I was thinking about it because of the need, sometimes, to trim the implement by adjusting the top link. For example, we are taking delivery today of a sickle mower. The manual refers to adjusting the plane of the mower bar by adjusting the top link. Other examples are the rotary mower, box scrape with scarifiers and the pulverizer. So as part of my project to make our setup more user friendly I was thinking of making it easier to trim implements like this from the tractor seat. But you make a good point about making it more difficult to fit the top link when you first hook up due to its weight and the hoses. I'll have to think about that.
   / Pat's Easy Change System - Order Online! #493
Our Ford sickle mower came with its own top link that only had to be adjusted once for the style of tractor that it was used with. It had arm clamps that we put in place by hand tighting then we used the lift to put in the top link pin THEN we torqued the arm clamps.
I think a hydraulic top link has its place. It seems like on a 3PH set of forks or materials bucket the extra lifting range would be nice that a hydraulic top link offers if one already had a spare remote.
   / Pat's Easy Change System - Order Online! #494
Today we got a BEFCO sickle mower. The dealer's rep and I put it on our L3800 using our Delta Hook QH. It was a struggle. Then after I did some mowing and wanted to take off the mower, I couldn't get the QH to release, and I ended up having to take the female QH unit off of the mower, which required me to lift up the mower to relieve some weight pressure. I finally got the tractor and the mower separated with the help of a crowbar to realign the Delta Hook pairs. This experience convinced me that our existing QH system won't work with the sickle mower. The quandry now is what to do--adopt an entirely new QH system, take off the QH system units when I use the sickle mower and hook it up the old way without QH help, or buy a new QH system for use primarily with the sickle mower, which means taking off the QH system used with other implements so I can put on the new system for use with the sickle mower. I am leaning toward an entirely new system, probably Pat's system. Any feedback, arguments to the contrary, etc., would be appreciated. Thanks.
   / Pat's Easy Change System - Order Online! #495
We have a mix match of equipment and 1976 tractor so when I learned about Pat's system it was a no-brainer.
   / Pat's Easy Change System - Order Online! #496
Gail, you triggered a thought: I think I'll try Pat's system for general use and buy a separate top link to use for the sickle mower. We can either adjust it for the proper mowing-blade plane once, and leave it there, or we can mark the proper length adjustment on the top link, change it as we need to for the hook-up, and then adjust it back to the previously marked correct operating position. Thanks.
   / Pat's Easy Change System - Order Online! #497
I have the same question about the set screws. I understand they are used to align the PEC plumb to the lift arms. However, when using implements with pins of varying widths, the PEC will sit square to some pins and be slightly off with others.
In other words, if my arms are set 26'' apart and I plumb the PEC and tighten the set screws, the PEC will be square to the pin on any implement with pins 26'' apart. When I move to another implement with pins 21" apart, the PEC is no longer square to the pins and the hooks will sit at a slight angle to the pins.
What is the advantage of using the set screws and tightening the PEC to the arms? Why not use the main pin through the ball in the lift arm and the shim and leave the set screws loose (or off) and allow the PEC to move left or right on the arm. By doing this, the PEC can self align to the pins on the implement being used.... this is no different then the ball in the arm rotating. What am i missing about the use of the set screws? Thanks
I got mine installed today, backed up to the bushhog that was not on level ground and that has always been a PITA to hook up and wow was that easy! After using that I dropped the hog off (and wow that was easy except for the fire ants I didn't see!) and backed up to the box blade.
Well, I've got to move the arm width now (need to make some spreader bars since I didn't order one, and need some more bent washers) and I agree with this quoted observation. I'm looking at it and am wondering the same thing- why do I need all of the rigidity and angle changing at different widths and why not just let it float on the ball in the arm? That would also allow me to adjust my box blade angle further when angled to do a trench.
I see that it's part of the patented difference between some other quick hitches, but...pros and cons?
   / Pat's Easy Change System - Order Online! #498
I like the regidity because that is the way our OEM ends are. With them flopping the flop will just get worse as they wear at the contacting points. I like the control of the arms lifting when I move the control.
   / Pat's Easy Change System - Order Online! #499
I have a Kubota B2910 and a Woods back blade. I ordered the Pat's Easy Change from Tractor By Net. Will it be difficult to install and will it work with my rear blade>
   / Pat's Easy Change System - Order Online! #500
Based on my experience, it will not be difficult to install. I bet that you already have it on by now. The only problem I encountered was that the spacers provided to align the quick hitch with the tractor 3PH arms did not work exactly right. One was a little thin and the other was a little thick. I ended up choosing the spacer (which was the thinner spacer) that came the closest to making the quick hitch be level at about the height of the lift pins on most of my attachments. I have learned that it definitly helps to use the stabilizer bar that I bought as an option with the quick hitch. You could make your own. I use the stabilizer bar to set the 3PH arms at the correct width for the particular attachment, and then I remove the stabilizer bar. Since the lift pins are not the same width on all of my attachments, I also have made some little wood measuring sticks I use to tell me how far apart to set the ends of the stabilizer bar for each attachment. Most of the attachments are the same width between the lift pins--28" as I recall. Some are not.
As to using Pat's system with the rear blade, I think it will work fine if you have the blade standing up. I intend to make a dolly for my scrape blade, and I intend to build the dolly so that the blade is standing up just as if it were attached to the tractor.
One final note is that I experienced the same thing I had read about on TBN with my top link being too short on some attachments due to Pat's easy-change system moving the connection point about 4" farther back. Yesterday I bought at Tractor Supply Company a longer top link that should fix this problem. I don't yet know if the PTO drive shaft is long enough on every PTO-driven attachment after the attachment is moved back this 4".
WOODS BRUSHBULL XTREME BB840X 7' ROTARY MOWER (A57192)
WOODS BRUSHBULL...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2016 Dodge Ram Promaster 1500 (A53317)
2016 Dodge Ram...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
1986 Hobbs Cone Star 35' Dump Trailer (A56469)
1986 Hobbs Cone...
