Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #201
do these work on the new Bobcat tractors...
   / Pat's Easy Change System - Order Online! #202
PATG said:
Sorry, it took so long. Was out all weekend. It is a little different design, but no major differences. AgriSupply has decided to aggressively market these as a set only.
Pat I did have a question about the one for my Montana. The shim that fits at the bottom between the easy change arm and the three point. There were two sizes of shims I have a montana 4940C and the thinnest shim was still just a bit too thick. what would you recommend I use instead of the shim ?
   / Pat's Easy Change System - Order Online! #203
gemini5362,
The smallest shim is 1/4". If it is to thick, then you probably don't need any shims. The Montana tractors have very stout lift arms. Of course, the 5740 are the worse. They have a bracket around the ball and we made larger receivers just for them.
   / Pat's Easy Change System - Order Online! #204
thanks pat
By the way you can add me to your list of people that love your product. It is so nice to spend 5 min getting my implements hooked up instead of 15 to 30 trying to get them in place. With the turnbuckles on the montana that hold the 3 point in place i just pull up to my implement and then place the 3 point hitch under the pins. I adjust the turnbuckles until the 3 point hitch arm is directly under the pin. I go ahead and hook up the top link and then get back in my tractor and raise the 3ph until it latches. It does not get much easier than that.
   / Pat's Easy Change System - Order Online! #205
Hey fellow tractor owners, first post here:
Does the new Kubota B2620 require a special version of the Pat's Easy Change System. Would this tractor need the system that is adapted for some of the other "B" series tractors? I am ready to order my system, I just want to make sure I get the system that will best fit my tractor. Thanks in advance.
   / Pat's Easy Change System - Order Online! #206
Greatdane,
Just put your model # in and add me a note in the comments section and I will make sure you get the right ones.
Thanks
   / Pat's Easy Change System - Order Online! #207
I love my PEC hooks - bought them 2 years ago and can hook up all the implements myself with half the wrestling and none of the swearing. Convinced my dad to get a set as well. I'm sure he still swears, but he did admit they make his life easier.
I did have a problem though with the implement wiggling the washer and popping the ring pin off the end of the ear. I have the Cat 2 size, and this happens mostly with my Cat2 mower, but has also happened with my cat 1 pinwheel rake (using the sizers). it does not happen with my Cat 1 brushhog (also using the sizers)
I saw it before the implement fell off, but I was kind of alarmed, and figured I must have put the washer on wrong. Is the folded end supposed to face towards or away from the center? I have put it on both ways, using the one that allows the pin to snap closed most effectively, but sometimes it wiggles loose and the ring snaps up and the pin could come off.
   / Pat's Easy Change System - Order Online! #208
Maybe a stouter spring clip would help. I can hardly open mine without a screwdriver blade. Never had that issue myself.
   / Pat's Easy Change System - Order Online! #209
Anybody want to buy a used Pat's easy hitch system. I still have the original box, instructions and all parts that came with it. $100 and I'll ship it free. Drop me an IM or an email if you are interested. It's for a Cat-2. I'll throw in the stabilizer arm thingee for an extra $10 (I'll ship it seperate). The plastic handle on it (stabalizer arm) was broken in shipping but it never hurt it's functionality for me.
   / Pat's Easy Change System - Order Online! #210
excellent price~!
curly said:
Anybody want to buy a used Pat's easy hitch system. I still have the original box, instructions and all parts that came with it. $100 and I'll ship it free. Drop me an IM or an email if you are interested. It's for a Cat-2. I'll throw in the stabilizer arm thingee for an extra $10 (I'll ship it seperate). The plastic handle on it was broken in shipping but it never hurt it's functionality for me.
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2018 Dodge 5500 Bucket Truck 4WD (A56436)
2018 Dodge 5500...
KUBOTA LA525 TRACTOR (A59823)
KUBOTA LA525...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
