Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #191
Is there any difference between the Pat's system sold via the TBN link, and the one sold by AgriSupply?
   / Pat's Easy Change System - Order Online! #192
It used to be quicker response...:D
   / Pat's Easy Change System - Order Online! #193
Sorry, it took so long. Was out all weekend. It is a little different design, but no major differences. AgriSupply has decided to aggressively market these as a set only.
   / Pat's Easy Change System - Order Online! #194
I see the Pat's Easy change works on the Kubota L4740 (which I'm planning on buying).
Does it also work on the Kubota B3030?
   / Pat's Easy Change System - Order Online! #195
Charlesaf3,
Yes, they work on the B series. We have some with a shorter receiver that gives you extra turning room on the short arms of the B series.
   / Pat's Easy Change System - Order Online! #196
Thanks Pat.
I'm not sure exactly what you mean by extra turning room on the b3030? And does it interfere with the telescoping function of the rear arms?
   / Pat's Easy Change System - Order Online! #197
Charlesaf3,
No, it doesn't interfere with the telescoping function. The arms on the B series are at an angle that you need to angle the hook back, so you need just that little bit of room to properly align.
   / Pat's Easy Change System - Order Online! #199
Is the easy change system from Northern Tool the same as PAT's? I see they are $169, S&H is about the same.
   / Pat's Easy Change System - Order Online! #200
Agri Supply has the best price. Includes Stabilizer Bar. Received mine yesterday and had it on in less than 15 minutes. Works great.
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
207283 (A52708)
207283 (A52708)
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
12' Container W/Side Door and Window (A57149)
12' Container...
