Pat's Easy Change Pat's easy change system-any problems?
/ Pat's easy change system-any problems? #1
artp
Southern Illinois
Kioti CK30HST
I read several posts on TNB and I am interested in the system, but I wanted to know if I would need to modify anything to my Kioti CK30HST to use the system with a Kodiak 5ft box blade, Kioti 5ft finish mower, and Kioti 5ft tiller. There is some discussion about needing a longer top link with some tractor/implement combinations? Any other problems?
/ Pat's easy change system-any problems? #2
artp,
I have a 5 foot Woods blade on my BX1800 and after wrestling to get that thing on a couple of weeks ago, I ordered a set of Pat's EZchange system. I got them yesterday and installed them right away. I can use my toplink with the system, but if I wanted a more aggressive cut when pulling the blade, I'd probably have to get another toplink to get more extension. Since I don't anticipate needing to do that, I am all set with my toplink. I have had the blade on and off the tractor since yesterday about 6 times (a few times just to convince myself that it's really that much easier than it was before) and it's really a pleasure to have on the tractor. It is very ruggedly constructed and I can't imagine doing anything that will make it fail. I had read that the directions were not that great, but I had no trouble with them....installation was about an hour, but I was really just dubbing along and taking my time. I also got the optional support post to keep the lift arms at the correct width, which I think would be necessary to make them as easy to use as possible, but I've also seen posts where TBN members have devised their own cross beams.....not very complicated to do. I wouldn't let the potential of needing a new toplink hold me back from getting the system and I'll be interested to see what others have seen for problems with the Pat's system. It sounds like you have also read the thread on Pat's EZchange, as I did, and I was impressed that if you have any questions, you can call Pat directly and he'll help you with your specific applications. Dyer, retired
/ Pat's easy change system-any problems? #3
I had to buy a new longer toplink, got it at TSC for around $30 (I think) still very handy and I use it all of the time.
/ Pat's easy change system-any problems? #4
I've had quick hitches and I've had Pat's.....Pat's wins by a long shot. I use a hydraulic toplink with Cat II implements and changing is no problem at all. Even though there are standards for the connection spacing on 3-pt implements, no one seems to follow them. Pat's gives you the flexibility to adjust without having to buy a bunch of bushings or plates for everything you own, or having to take something off your tractor to hook up to an implement you borrow.
/ Pat's easy change system-any problems? #5
I had to get a longer top link as billbill1 said. I got mine at TSC also about same price. I use the Pats system on my box blade, scraper blade, bush hog, finish mower, plow, disk, and lifter. The longer top link is a necessity when using the finish mower. The Pats system puts the implements back 2 to 4 inches than without it. It is a very good system but as I am a old coot, I would like to have somebody do it for me while I set on the tractor, but my wife has not agreed to do this. She did have a suggestion for me, but i cant say that here.
/ Pat's easy change system-any problems? #6
I've implemented the perfect system for me.
Pats for the lower arms
hydraulic top link..solves both the longer top link question and EASY adjustment
I made attachments from PVC pipe that fit over the handles that operate the 3ph and the top link... handles reach to rear. I can stand at rear of tractor and manipulate the top link and 3ph arms for hooking stuff up.
Nothing easier.
As many have said, PAT'S manufacturer stands behind the product... problems have been extremely few, but fixed IMMEDIATELY when they do happen.
Thanks for all the posts guys! It seems that a longer top link is the only item mentioned so I am going to order the Cat1 with the support post. I too am getting along in years and any help I can get to simplify changing implements is welcome.
/ Pat's easy change system-any problems? #8
I've got one and think it was worth the money. My original toplink still works with all my implements. Only problem I had was that there are two springs that keep the catch retracted (or is it the other way around?) when you hook up. Those springs broke right away but I find it is easier to use without the springs.
/ Pat's easy change system-any problems? #9
I had a small problem. I bought the Cat-1 Pat's hitch and had them drop ship it to the place that was selling me my tractor. They put them on and then decided they wouldn't sell me the tractor for that cheap so they sent the Pat's hitch to me. So, the tractor I ended up getting was cat-2. I called Pat, they sent me a Cat-2 (difference in price) and I sent them back the cat-1.
So, it wasn't actually a problem with the system, I just wanted to plug them for their great customer service.
/ Pat's easy change system-any problems? #10
There must have been a batch of bad springs... one broke quickly for me, too. I called Pat and they sent me 2 in the mail... no further breaks.
/ Pat's easy change system-any problems? #11
For many years I would wreste and cuss my heavy impliments every time I had to change them. I purchased Pat's system this year and what a difference!! MUCH easier and certainly worth the price IMHO. Wish I had found them years ago. I have had no issues with my stock top link, JD 4700.
/ Pat's easy change system-any problems? #12
Welcome to TBN!
/ Pat's easy change system-any problems? #13
Product and customer service are second to none. My toplink was also too short. Instead of buying a new one, I cut the one that came on the tractor and welded a four inch piece of pipe in it. Works great. Pretty easy decision for me. $200.00 for Pat's or $2500.00 everytime I am in the hospital for hurting my back.
Terry
/ Pat's easy change system-any problems? #14
I really like mine, as it saves me a lot of work hooking up. I went to a longer top link, but I had intended to do that anyway.:)
/ Pat's easy change system-any problems? #15
my ck30 came with easy adjustment Telescopic ends. They are pretty easy to connect. I never have to move the implement to connect. Course, this is all I've used... ???
/ Pat's easy change system-any problems? #16
Dyer said:
Welcome to TBN!
Thanks for the welcome, have been reading here for a while, figured I may as well join in!!
/ Pat's easy change system-any problems? #17
Telescoping ends are great, the b3030 has them too. Still go better with pats - whose customer service is excellent
I actually have now moved beyond Pats to Delta Hook. Much better system. Much more money.
Just installed Pat's system yesterday. It took about an hour-I am not a mechanic-and I took my time. It went on without a problem. Hooked up my finish mower in only a few minutes. The tiller was a bit more time consuming but the hook up was sweet. I had read from other posts that the instructions were a little confusing, but I found them to be very clear and straightforward. I would highly recommend it to anyone, especially if you are getting along in years and do not want to man handle your implements.
Top link is fine for the finish mower and tiller. I did not have time to try the box blade, but I will check it out soon.
