SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,632
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
There is a design problem that will probably hit nearly everyone sooner or later if you get in the ruf. The lever handle that controls the pin lock lever is rather fragile in relation to Murphys Law. This lever hande is weakened at its root by a thru hole drilled for a roll pin that serves as an anchor point for the spring that holds the pin lock extended. If the handle breaks it will be here, loosing the anchor point. This allows the lock lever to retract and the implement pin to escape the "U". Better to anchor the spring to the lock lever vs the lever handle. That way, even if the handle gets torn off, the system will still work and doesnt throw you into emergency fix mode.artp said:I read several posts on TNB and I am interested in the system, but I wanted to know if I would need to modify anything to my Kioti CK30HST to use the system with a Kodiak 5ft box blade, Kioti 5ft finish mower, and Kioti 5ft tiller. There is some discussion about needing a longer top link with some tractor/implement combinations? Any other problems?
larry
