Forks Pallet Forks
/ Pallet Forks #1
tarious
Grand Forks, ND
JD 3320
Greetings,
I am interested in pallet forks for the FEL on a 3320. I have searched the forums and I haven't been able to find many posts about either making them or some of the brands available for purchase.
Have any of you fabricated your own, if so mind posting pics? I checked at my local green dealer and they sell a set that will mount right onto my 3320. My cost, 1300.00! Ouch!
I would like to buy/fabricate something that isn't soo tough on my wallet. It isn't an attachment that I would use frequently.
/ Pallet Forks #2
</font><font color="blue" class="small">( I have searched the forums and I haven't been able to find many posts about either making them or some of the brands available for purchase. )</font>
I don't think you looked hard enough. /forums/images/graemlins/blush.gif
I offer a free set of plans to build your own. Over 100 TBN'ers have requested them and some have even built ones based on these plans. I have built 6 sets myself. You can read about them HERE.
PM me with a real email address and I will gladly send you a copy of the plans.
/ Pallet Forks #3
When you search, be sure to change the "Date Range" to "ALL POSTS", as it defaults to only one week.
There have been numerous post about forks...Here is a LINK showing pictures of the set I made.
Try that search again using "forks", "FEL forks", and "Pallet Forks"
/ Pallet Forks #4
I made my own for cost of materials (30$ or 40$) and my time
/ Pallet Forks #5
I bolted two 6 foot lengths of channel iron under my bucket so that 4' stuck out forward and 2' rested under the bucket (one 1/2" bolt at the cutting edge through each channel). I found there was too much side to side play initially (I wonder if this is a problem with some of the designs suggested so far?), so I bolted a piece of angle iron between the channels where they stuck out behind the bucket. For insurance, I looped some 3/8" chain over the top of the bucket from the back end of the channels. (Hope this makes sense)
Sounds too easy/light, but I've been able to lift enough to run out of power before overwhelming the forks.
Shawn
PS 30$ Canadian
/ Pallet Forks #7
I did not have a frame for my forks. They are from regular lift truck. We just added to the top and I curl my bucket to catch the round pipe then "un-curl" and my forks are ready for use.
I am able to vary spacing with this setup.
/ Pallet Forks #9
I built mine from C channel I obtained at the local scrap yard and misc. threaded rod from TSC. Total cost about $40. They will habdle more weight than my bucket can lift so I'm satisfied with that. I would have used regular forks from a forklift and used a pipe along the top then welded hooks on top of the bucket to hook into but couldn't find any in my area.
George
/ Pallet Forks #10
That's a VERY nice design, gotrocks. I haven't seen this done before.
Good job! /forums/images/graemlins/cool.gif
/ Pallet Forks #11
Although you might spend some more $ this way, the forks that JD sold me fit my FEL quick attach mechanism nicely. I can change out my bucket and forks in about a minute. I find I do that a lot.
/ Pallet Forks
Thanks for all the info! I knew some of you would have some solid inexpensive solutions.
Thanks again
/ Pallet Forks
Bebster, do you have any pics? Also, mind sharing what you paid?
Thanks
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2008 DRESSTA TD-15M EXTRA CRAWLER DOZER (A65053)
2008 DRESSTA...
Honda EM 7000is Inverter Generator (A64553)
Honda EM 7000is...
12ft S/A Utility Trailer (A64557)
12ft S/A Utility...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
