Pallet fork recommendations for 770?
/ Pallet fork recommendations for 770? #1
NickTaylor
Maypearl, Texas
1998 John Deere 770
Will be receiving a bunch of sod soon for a new lawn. Any 770 / 790 / 3005 owners have pallet forks that you like? 3 pt or bucket mount? Pics would be great.
/ Pallet fork recommendations for 770? #3
That is a relatively small loader, does it have the John Deere Q/A?
/ Pallet fork recommendations for 770? #4
also check the specs to see what you can lift. my old 870 could only lift 900#. i was going to add some clip on forks, but after weighing the forks and the bucket, there wasn't enough available lifting power left to move the pallets of stuff i needed moved.
I'm definitely limited on lift capacity with 770 and 70 loader.
The Artillian option looks great but I'll have to save my nickels for awhile!
/ Pallet fork recommendations for 770? #9
Yes, but with your limited capacity (I mean the tractors :laughing: that is) you need all the help you can get. They are the only ones available that will replace your bucket giving you the most lift capacity. You will be very disapointed with the clamp-on style forks.
/ Pallet fork recommendations for 770? #10
Generally i cant agree more that the clamp on forks are no wheres as nice as the QA style (like i have myself). However if he only has 700# lifting capacity, you dont want to add a 200 - 250# plus set of forks. this will limit his lifting capacity even more.
I have a friend with an older small Kubota tractor and he made himself a set of front forks and they work great for the 500# or less stuff he lifts.
Thanks for all the advice. Someday I'll get a bigger machine (after my 4 teenagers get thru college - #?!£€%#). For now the 70 loader will have to.
Sounds like forks in place of bucket is the only realistic option....
/ Pallet fork recommendations for 770? #12
The Artillian forks are 200 lbs and my 53" bucket is 170 from the factory (mine is reenforced for bucket hooks and a tooth bar so it is probably closer to 230 lbs). The forks add a net 30 lbs to the weight not 200 lbs.
One other things, clamps-on forks will add more than 30 lbs and they also move the load further from the pivots reducing the lifting power even more.
/ Pallet fork recommendations for 770? #13
I'm surprised more have not mentioned this... Honestly, with your load limitation I would go with something off the 3PH like a carry all type deal for more lifting capacity! There are allot of options, and I think some of which are a good bit cheaper as well.
/ Pallet fork recommendations for 770? #14
As a light duty example this carry all (made by many companies) will work with a pallet, is very inexpensive, and will carry about 500lb IIRC which is all you would get with your loader mounted forks anyway.
CountyLine Carry All - 2128210 | Tractor Supply Company
This pallet mover (also made by many companies) will do 2,000lb and is still less then the fork options, and will give you more lifting capacity then with your loader.
King Kutter Pallet Mover, Model# PM-15 | 3-Point Category 1 Implements | Northern Tool + Equipment
You rear 3PH lift is only rated at 815lbs (less then I expected) at the ends so honestly, I would just go with any decent carry all you can get your hands on.
Not to mention the added safety factor lifting from the rear... To me this is a no brainer, I would not even consider loader pallet forks unless I needed the lift more so then the carry aspect.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
Winco 12-Ton Fertilizer Tender Box (A66408)
Winco 12-Ton...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
