17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up.
I would have thought the same thing a few years ago with Deere. This is what I found this morning. A new hydraulic leak on top of the transmission. It looks like the tee is leaking. It just never ends with this tractor.
That is crazy to see. A pioneer fitting on the back of ours is leaking, and I have to look at that as well.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #62
Thanks for the update. I agree that the driveshaft cover is a total joke. It is unbelievable that John Deere won't replace this driveshaft cover. My new cover keep spinning and rubbing on the oil pan, so I shimmed each end to stop it. My hydraulic leak was a loose fitting on the tee. I really hope they get you're issues fixed. Keep us updated.
The service tech said the driveshaft cover had a TSB, and they will have an updated one that supposedly fixes the issues. They should be able to order it for you. They have escalated the case, but they are waiting to hear from JD and what they should look at next as they do not know what could be the problem. One area of concern was all the oil built up on the fan and engine when we took delivery, which makes us wonder about the tractor's history. The tech was here for 3+ hours Monday and Wednesday, and I had him make a note of it.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #64
I am guessing that a tsb is a technical service bulletin? If so they have not contacted me on that. My 4066R had over 800 hours on it and the drive shaft cover was perfect. This 4075R has performed the same tasks as it did. So is the driveshaft turning faster on the 4075R, or what the hell is the deal? I find it hard to believe that anyone reading this forum would want to have a 4075R. Thanks for the update.
The tech stated the newer one was thicker and had other changes.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #66
Hopefully the inside diameter stayed the same because it barely clears the driveshaft couplings. If the outside diameter is larger and fits tight on each end to keep it from spinning, it would be better. Let us know how it works for you. This time of year I don't use mine as much, except for downed trees and cleaning out gutters. If my wife lifts me up in this modified tote.
I believe they installed the new one on Wednesday, but I can take a few pictures and upload them. There is no ETA for repairs on mine, as they do not know why it's not lifting or why the new pump flows even less. It's flowing 1.5 gpm less than my prior tractor and 3.2 gpm less than the specs. I'm at the point where I would prefer it to be taken back. The fact that it showed up with the fan and front engine coated in thick oil makes me question the history of the tractor. Of course, the dealer refuses this, but I did in an email request to return in writing before the 30-day limit.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #68
Thanks for the update, I feel your pain. I will most likely never trust my tractor, so I don't take it any farther from the shop than I would want to walk back.
The dealer really came through and is buying the tractor back. It's about a 4k loss. Hopefully, we can find something quickly; only JD, Kubota, Massey, and Yanmar are close to where we live; Kioti is over an hour away.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #70
4k loss to them? or to you?
For me it would have been even more but the dealer let me return the pallet forks I bought for testing and over $400 in filters and oil.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #72
Which dealership are you leaning toward? I'm surprised a new tractor needs attention at all for the first thousand hours. Have you considered a lease with option?
Now that you've been through a few roughly similar tractors, I'm curious what are the lessons learned and what is the next step....
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #73
It is good to hear that you got the issue resolved. On the other hand I will miss your updates on this tractor. Good luck on your next tractor, what ever brand it may be. Thanks John
I'm at a loss now, but the 4075r would have been great if they could figure out what was wrong. Mine was delivered with many issues, and the loader was not lifting near spec. I was out and stopped by the Kubota today, but when asked about the L6060 lift capacity, they were unsure about lifting the pallets. I think the HST+ would be great on the steep hills here. They recommended the M6060, which I did a test drive. I may go by the Kioti dealer. They said the nx6010 is hard to find, but I know it will have no issues lifting pallets. He said they had the new 7340 with the electronic 3-point, like the JD, but I cannot tell the exact weight with the loader and filled tires. VA has a 26001 lb limit before medical and CDL. Even if your trailer is empty, you still get large fines if the gross vehicle/trailer weight exceeds that. The largest trailer I can tow is 14k to stay under that limit.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #75
I've had Kubota, Deere, Ford and flirted with IH. Originally, I wanted all Deere but when I had a problem with the draft control on a new 90 HP Deere, the dealer took the tractor in but it was in the exact spot I left it when I came back a couple times. I'm pretty sure they never looked at it. The problem didn't get fixed until I fixed it myself. I realized then that if I ever needed them they wouldn't be there.
So I bought Kubotas from a nice dealer and so far only little issues that they did more than they should to make me happy. I'm slowing down now and selling stuff but Kubota worked for me because the tractors rarely had issues and when they did, the dealer jumped through hoops to keep me happy. They even drove a part out to me on a Saturday despite my saying not to. But, I beat the rain that day.
The dealer makes it all work but the manufacturer has to sell enough tractors to keep the business profitable. You have to buy from a manufacturer that sells a lot of tractors and is able to support a dealer network for service and sale. Smaller brands often can't catch up.
The hard part is finding any brand in stock and examining the cabs and their layouts. The 7340 was a nice-looking tractor, but after adding up the weights, it would require a CDL unless I bought a bumper-pull aluminum trailer 24ft or less. I'm looking at the 2860m and NS6010; there is about a 10k difference with similar builds. Finance rates are very close between the two. I have never sat in a Massey, but no one near me as ns6010 or 2860m.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #77
Good call with the NS vs NX... The NX is pointlessly complex IMO, I guess even a used kioti DK40/45/50SE is pretty cheap lifting power. The Kioti's need 1000lb+ of ballast on the back to use the loader near its max safely, and I have lifted up the back end with the curl even with the ballast on...
On paper, I tend to lean towards the 2860m, but no one within a 2-hour range has either tractor for me to look at. When they loaned me the 4044m/400e to take deliveries, no cab, and it felt very light behind the truck. I added my big mower on the back and added another 600 lbs to that. It lifted over 2000 lbs and was very steady. I will get the backhoe for whichever one I go with; I like the specs on the BH85 backhoe vs the Massey 75, but I am waiting on the dealer to see if he can get that for me.
   / 17 Hours 4075r, It started making an odd sound. I needed to move 2000lb pallets of pellets and could not pick them up. #79
I like the weight on the 2860m more, a 1 ton pallet is a lot!
Maybe I don't have your story straight? But I don't think I would deal with the same dealer that cost you $4k for a broken tractor with 17 hrs on it? With a relatively simple problem to diagnose? Seems they are too big to care, or too dumb, or too greedy, to get your old tractor right?
IMO, JD has so many pieces of equipment, made by so many different manufacturers, how many good techs does a dealer need to have someone in the shop that can work on your tractor with any experience? I'm not saying smaller brands are always better, but they have much fewer tractor models to figure out, and usually they are designed by the same engineering team.
Personally, unless you dealer just refunds all your money on the old tractor, I'm not giving them another chance to mess up at my cost again....
You are correct. Quick overview: It spent seven days at one dealer, and then a tech spent another two days at the property before taking it to another dealer. All troubleshooting stopped when the new pump was worse off than the old pump. They did not know where to start next, so they opened a ticket with JD to get further instructions. One dealer wanted a special sensor kit for all the hydraulic connections. I'm interested in the YT359c as well; my prior 55hp struggled to pull the mower on them. Would the drive system in that pull better on the hills vs HST? I'm thinking of asking that in the Yanmar forums.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
CASE CX31B EXCAVATOR (A60429)
CASE CX31B...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
KIOTI SL7504-PL SKID STEER (A60429)
KIOTI SL7504-PL...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
