bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,924
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Ironically, I've never had a cable come off the drum when using any of my overhear door openers. It did happen though when I installed the second jackshaft opener. I got careless when setting the door speed and down stop. No damage luckily but it was quite a hassle to get it back together. I know there is supposed to be a slack sensor in the system but it didn't work for some reason. I had to lock the shaft with vise grips to keep it from turning and use a floor jack to lift the door to get enough cable slack to slip it back on the drum.Dont know about the genie.....
But yes the electronic stops are critical. But same for a conventional opener or you can damage the door.
But even if the electronics fail.....there is a cable slack sensor. The split second there is no tension on the cable, the door will stop and reverse.
As long as its installed properly, I have never seen a slack cable come off the drum on a jackshaft opener.
But even if it did.....it isnt any different than a cable coming off the drum on a conventional opener...which I have seen happen as well for various reasons
