Options for BX23
/ Options for BX23 #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
Hi group,
I've narrowed down my tractor shopping to either a BX23 or a comparable Massey Ferguson. My question here has to do with the BX23.
1. There is an option for a high capacity alternator. What would necessitate that? If I wanted to have the option to add a few work lights, the stock alternator should be fine, I'd guess, right?
2. Does a BX23 have auxilary hydraulics? I don't see that listed as an add-on option if not.
3. Would I be better off with bar tires or turf tires with tire chains? I don't plan to do any mowing with my new tractor. It'll be for digging ditches, holes, and moving wood around. But it was also see time in the winter to assist with snow removal. I have a long driveway, and certain parts of it are quite steep.
Thank you
/ Options for BX23 #2
If you plan on getting lights later I would get the higher amp alternator. The high amps is 40amps - I believe the standard is only like 15 amps. Not enough to run too many lights.
There is no factory option for auxilary hydraulics at the moment. Nasdaqsam added a really slick thumb setup to his BX23 ( search thru the Kubota forums it is was within the last month or so) and used some Kubota parts for his setup. I believe he also mentioned in one of his posts that a Kubota rep said they were looking into aux hydraulics for whatever that is worth.
/ Options for BX23 #3
Don't forget the block heater. It makes cold starting much easier. I have turf tires and have no problem plowing snow, except for the front end slipping sideways a little if the blade is angled sharply. I just picked up a set of front bar tires that I filled which should eliminate that problem. From what you stated, bars are probably a better choice, and have the rears filled. If you ever plan to add work lights get the alternator kit. You also might ask if they could throw in a couple of grab hooks welded to the FEL.
/ Options for BX23 #4
If you want to add a rear hydraulic valve to the BX23, it is quite easy. Kubota does have a kit for this, but it is difficult to hook it up the way that they have it set up. I modified it to work on the BX22 last year. If you decide to pursue this option, let me know and I will try to find the original post. The picture was taken during the early stages of the install.
Get the bar tires and forget the turfs. Not needed for general work and the bars will not damage your turf unless you are extremely careless.......
The high output alternator is a must if you add some additional lighting . If not, then the stock unit will work fine.
Junk..
/ Options for BX23 #5
</font><font color="blue" class="small">( Hi group,
1. There is an option for a high capacity alternator. What would necessitate that? If I wanted to have the option to add a few work lights, the stock alternator should be fine, I'd guess, right?)</font>The Alternator is a good idea. You may not want extra lights now but may in the future and it esier to do from the get go.
</font><font color="blue" class="small">( 2. Does a BX23 have auxilary hydraulics? I don't see that listed as an add-on option if not.)</font>There is a lot of good threads here on TBN regardingthis option. I just got done doing it myself. I can highly recommend following the thread Junkman wrote on how he did his.
</font><font color="blue" class="small">( 3. Would I be better off with bar tires or turf tires with tire chains? I don't plan to do any mowing with my new tractor. It'll be for digging ditches, holes, and moving wood around. But it was also see time in the winter to assist with snow removal. I have a long driveway, and certain parts of it are quite steep.)</font>I agree with the others that said go with the bar tires. However your last statement gives me pause. You say your driveway is quite steep. Is it paved? If not then the bars would work well for you. If it is then I would go with turfs and chains. No rubber product is going to give the traction chains will on hard surfaces.
</font><font color="blue" class="small">( Thank you )</font>Your welcome.
/ Options for BX23
</font><font color="blue" class="small">( You say your driveway is quite steep. Is it paved? If not then the bars would work well for you.)</font>
It's not and won't be for quite a many years if ever. Thanks nasdaqsam. /forums/images/graemlins/smile.gif
/ Options for BX23 #7
</font><font color="blue" class="small">( ( You say your driveway is quite steep. Is it paved? If not then the bars would work well for you.)
)</font>Your welcome. I had visions of you sliding down the driveway.
/ Options for BX23 #8
<font color="blue">1. There is an option for a high capacity alternator. What would necessitate that? If I wanted to have the option to add a few work lights, the stock alternator should be fine, I'd guess, right?
============= </font>
1*If you do it right you shouldn't need the alternator upgrade.
3*I prefer the AG tires.
/ Options for BX23 #9
</font><font color="blue" class="small">( 1*If you do it right you shouldn't need the alternator upgrade.)</font>
Please define "do it right". The stock alternator is barely enough to keep the battery charged with the stock lighting system. I can't see how doing it right has anything to do with this. It is a simple equation of the total output of the stock alternator being able to satisfy the amperage / wattage needs of the additional lighting. If you leave the stock factory lighting off, then the most that he could still add as auxiliary lighting would be about the same wattage as the factory installed lighting. That is why they offer a high output alternator. Actually, the original equipment unit is referred to as a dynamo, not an alternator.
</font><font color="blue" class="small">( 3*I prefer the AG tires. )</font>
/ Options for BX23 #10
<font color="blue"> 1*If you do it right you shouldn't need the alternator upgrade.
</font> DHD . . . I don't know if your dealer is 100% accurate or not, but I really do believe that there is way too much made of the alternator size needed to run lights. Most of us run our tractors the majority of the time during the day. Most of us who have extra lights don't run them constantly. There are many examples of little BX series Kubotas with 2 to 4 auxilary lights being run very successfully by folks here in TBN. For someone who runs their tractor at night most nights and wants enough light around his tractor to be seen from the space shuttle, then I suggest that you size up your alternator. But if you snow blow a few hours a week on a winter night, and still use your tractor during the daylight hours, I suspect there will be no problems. Further, I think my suspicions are backed up by the LACK OF PROBLEMS reported here on TBN. If it were a problem, we would all be reading about it right here!!!
Bob_Skurka
Shortened Very Long URL
CK30 3320 B7800 B3030 L3400 TC33DA TC30 winner is.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example.
/ Options for BX23 #11
You can, you just 1 though. The little dyno only puts out 15 amps which will run 1 work light with leftover for the charging system.
Neil Messick
Messick Farm Equipment
Tractor Sales / Computer Support
Central PA, NJ, DE, MD, NY, VA,CT,MA )</font>
#686181 - 07/03/05 04:42 PM
If you take 30 amps out and the dynamo is only capable of putting 15 amps, then the balance is going to be coming from the battery. As long as the tractor is running, and the battery has sufficient charge, there is no problem. Once the tractor stops running, then the battery might not have enough reserve capacity to start the tractor again. A prime example of this is police cars, ambulances, and fire trucks. The lights, siren, radio all pull more amps than the alternator can replace. That is why they keep them running once they get on scene. That is also the reason that many of them have dual batteries. They run on one and leave the other for starting when the first one won't do the task.
/ Options for BX23
Well, assuming that I get a BX23, I'll be getting the high amp alternator. The tractor needs a car stereo. /forums/images/graemlins/smile.gif
/ Options for BX23 #13
</font><font color="blue" class="small">( ............ The tractor needs a car stereo. /forums/images/graemlins/smile.gif )</font>
The tractor needs a <font color="red">TRACTOR</font> stereo /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2007 FORD FREESTYLE SEL (A60430)
2007 FORD...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
Bradco 6HFC Hydraulic Trencher Skid Steer Attachment (A59228)
Bradco 6HFC...
Takeuchi 14.9 Yard Skid Steer Bucket with Teeth (A59228)
Takeuchi 14.9 Yard...
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
