Opening ditch lines
/ Opening ditch lines #21
70 hp on a 5' non-offset rear blade, hmmm, might work in Florida but doubt it will work around rocks. Need a 7 foot offset-able heavy duty one!
A pond scoop (dirt scoop) might work, and a middlebuster might break up the ditch so that you can use the 5 foot rear blade without tearing it up.
David from jax
Sandman is right, a heavy duty 6 way blade will do it but a light weight one probably will break or bend. If you don't have one or know where you can rent or borrow one then hiring someone to come fix it once might be your best option. Once fixed you can maintain it with a lighter blade.
/ Opening ditch lines #22
Just for the record, I own an M7040... and I used to own a 5' non offset rear blade, and that was in Florida!
It caught a pretty good sized root and in a split second was transformed into scrap.
David from jax
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2023 Paladin Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
2023 Paladin...
CAT 621B Final Drive (A68134)
CAT 621B Final...
