Once again- B2630 vs. B3030
   / Once again- B2630 vs. B3030 #1
QuartzCreek
Virginia
I'm trying to decide between the B2630 and the B3030. Question for those who secured the former- any regrets? Do you wish you purchased the 3030 instead? Any 3030 owners who wish they saved a grand or so by getting the 2630?
Decisions, decisions.
Mike
   / Once again- B2630 vs. B3030 #2
I got it down to the same choice you are making. Went with 2630 mainly because of the grand difference in price. It seems to have more then enough power for what I do. Handles very well which helps in the woods. I have had the B-2630 about six weeks. All is well.
   / Once again- B2630 vs. B3030 #3
I throw a little bit of a curve to this in that I wanted the cab, so the B3030 was the easy and only choice for me. Depending on the job it has all the power you need. If the job is bush hog or ground engagement the more horsepower the better. The B3030, with a 5' rotary cut mower, gets it done, but grunts through it with 24' to 30" high grass. To quote someone else wiser than me on the forum, you have never heard anyone complain about too much horsepower. The converse certainly isn't true. The $1000 though buys you that rotary cut mower.
   / Once again- B2630 vs. B3030 #4
I bought the 2630 and I am very pleased with it. For what I will be using mine for, it was my choice over the 3030. What will be your uses with the tractor? Maybe we could help a little better if we knew what you would be doing with it. Good luck in your decision!
   / Once again- B2630 vs. B3030 #5
The 3030 is worth the extra grand. What is the pto hp on the 2630?
   / Once again- B2630 vs. B3030 #6
According to Kubota,
2630 has 19.5 PTO HP
3030 has 23.0 PTO HP
I trying to decide the same thing. I'm a tightwad on a tight budget, so the 2630 is appealing. I do need it to run a 5' rotary cutter, but most of it would not be on 30" grass. Both seem capable of running 72" MMM or RFM.
Somewhere on here I've read that a rule of thumb is 4 PTO HP for every 12" of rotary cutter. That would say 20 PTO HP for a 5' cutter, or just about exactly what the 2630 has. If the 3030 grunts a little in the tall grass, I'm sure the 2630 would too, but how much more, and is that worth $1000 or so?
BCNU- We live on 11 acres of mostly wooded land. I plan to use my existing (and paid for) simplicity for mowing. New tractor will be used for moving mulch, gravel, stone, etc for multiple landscaping projects, excavating for a couple of walkways, maintaining a 450 ft gravel driveway, snow removal, leveling some soon to be cleared areas, and clearing brush and scrub from various wooded areas. Other projects to be determined and as yet, unknown. I expect to buy a box blade and rear blade, and am considering a grapple per Cart99.
Kingoflawns- pto hp is 19.5 per Kubota website. I'd like to hear your reasons for saying the 3030 is worth the extra grand.
Any suggestions/thoughts that can be offered are much appreciated.
Mike
   / Once again- B2630 vs. B3030 #8
Having made the jump from a kubota 3 cylinder to the 4 cylinder, the difference is huge in power. Working in lawn fertilization & landscape construction for 3 decades, i can assure you that 4 hp at the engine and pto is a substantial amount of power. It may not look like much on paper, but its a lot when you are bogging down in dense vegetation.
   / Once again- B2630 vs. B3030 #9
I have had mine almost a year (2630). I got the TLB I also pull a befco 72" RFM and use a PHD, I have never lacked for any power. If you think you will have any power issues go with the 3030. If not save the $$$$ and go with the 2630 /forums/images/graemlins/smile.gif
   / Once again- B2630 vs. B3030 #10
Im sure you must stay right on top of your mowing. If you run that set up into tall wet grass with 19 pto hp and 72" of mower you will bogg down!
   / Once again- B2630 vs. B3030 #11
</font><font color="blue" class="small">( BCNU- We live on 11 acres of mostly wooded land. I plan to use my existing (and paid for) simplicity for mowing. New tractor will be used for moving mulch, gravel, stone, etc for multiple landscaping projects, excavating for a couple of walkways, maintaining a 450 ft gravel driveway, snow removal, leveling some soon to be cleared areas, and clearing brush and scrub from various wooded areas. Other projects to be determined and as yet, unknown. I expect to buy a box blade and rear blade, and am considering a grapple per Cart99.
Mike )</font>
With the exception of 5 acres of woods..and a 200 ft gravel drive...the exact same reasons I bought my B3030. IMHO..at times you MAY bog down the 2630...but Ive found that instead of bogging down the 30 HP version..I get into tire slippage...which tells me to go at it easier.
Nothing one can do when they might need extra "ponys"..except wish for them. If I could have bought the same physical SIZE tractor..with a 6ft FEL and more lifting power...Id have gotten a 40 HP engine...but even with the 30 HP..I dont have to run the engine "wide open" all the time to accomplish most tasks...except pushing over trees or grubbing out tree stumps.
   / Once again- B2630 vs. B3030 #12
</font><font color="blue" class="small">( I'm trying to decide between the B2630 and the B3030. Question for those who secured the former- any regrets? Do you wish you purchased the 3030 instead? Any 3030 owners who wish they saved a grand or so by getting the 2630?
Mike )</font>
Not I. I took over a month before I layed my cash down...before I made the final decision...and I went with the B3030
   / Once again- B2630 vs. B3030 #13
I like the sound of the 4 cylinder B3030 more than the 3 cylinder B2630. That may seem trivial but it was a factor in my decision to buy a B3030. I wanted a small tractor that would do anything I would ever need or want to do on my 3.5 acres. After spending $20K for tractor, FEL and MMM I didn't want to wish I had spent a little more and got the the more powerful engine. I wanted to do it once and do it right. I have no regrets. The B3030 is everything I wanted it to be. The B2630 would probably do everything I want it to also, but I never have to wonder if I should have bought the more powerful machine. If you KNOW you will never want more power, then buy the B2630. If you have ANY doubts now is the time to prevent that doubt from coming up in the future.
   / Once again- B2630 vs. B3030 #14
Quartz, Like I said earlier if you think you need the extra hp then go for the 3030. I have not experianced a shortage of power. Mine will spin the tires if thats what your looking for puching dirt /forums/images/graemlins/smile.gif (60" bucket also) I did have the extra $$ for a 3030 but just didnt see the need for it. So far I have not been short on power. If you check out the statistics it does have a slight edge in hydraulics compared to the 3030. 3 cylinder engine runs just as good as the 4 cylinder. As stated by someone earlier that I have to stay on top of mowing is speculation on there part. My friend and me both purchased our tractors at the same time me a 2630 and him a 3030 he loves his and I love mine. Both great tractors. Which ever one you pick you will be happy. Just my 2cents /forums/images/graemlins/wink.gif:)
   / Once again- B2630 vs. B3030 #15
19 hp pto is underpowered for a 72" rfm, thats not speculation mr devildog, its fact!!!
   / Once again- B2630 vs. B3030 #16
Well be prepared to be amazed and dazzled it pulls a befco 72" RFM no problems. Now my old 1951 JD b was rated at just 24 HP and it bent a 35 hp RB into a horse shoe. But here are the facts Click Here And this is straight from the kubota web page. It recommends for both the 2630 and 3030 the 5 and 6' models. All the same implement that are reccommended for the 3030 will also work just as good with the 2630. With the proper care either tractor will last a long time. I am pretty sure mine will outlast me /forums/images/graemlins/wink.gif
Quartzcreek, Just do your homework and go down to the local dealer and test drive them both and pic which one best suits you and what you need to do with it. I also do not regret the decision on my 2630. Great piece of machinery as compared to my old JD-B and you are still more than welcome to stop by and mow some tall grass with it. I just dont have the time
/forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif
Devildog- Thanks for the firsthand information; it's appreciated. I have driven both tractors. Just seeking information from those more experienced than myself who actually own either beast!
Mike
   / Once again- B2630 vs. B3030 #18
May not be true at all but my salesman told me that Kubotas dyno around 2 more PTO horsepower than they are rated at. This was after I had already purchased mine so he would have no reason to lie I guess. Like I said this is what he said, I don't have a dyno to know if he was telling the truth or not. Some one on here may know if its true or not.
   / Once again- B2630 vs. B3030 #19
This site may have some information on tractor specs. Don't know if it will include yours.
web page
Egon
   / Once again- B2630 vs. B3030 #20
Egon, Great site. Lots of good tests in there .
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 5075E (A53317)
John Deere 5075E...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
