Dirt Moving Old work horse 60’s , 70’s
/ Old work horse 60’s , 70’s #21
what kind of engine do you have in that 530 deere I don't think it will come anywhere near 70 to 90 hp that he is asking about ;-)
/ Old work horse 60’s , 70’s #22
Naw, that 530 engine is stock. But of course you could get the same tractor in 530, 630, 730, & 830 configurations. They all pull just fine; I've never heard of anyone wanting for power from ther 2 cylinder JD.
Part of that is the overall weight. Even the little 530 is around 5000 lbs bare.
Nowdays we quote HP for convenience, but it's torque that does the pulling & PTO work. Those two cylinder JDs had massive torque & lots of rotating engine mass....but relatively little HP. That's because they redlined at less than half the RPM that a newer tractors run at.
To reduce "Advertising Dept. HP Inflation", all the old tractors used the Univ. of Nebraska standard tests.
For anyone interested, those tests make good reading and are still available today. Here's a link to the JD 530:
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1080&context=tractormuseumlit
Enjoy, rScotty
/ Old work horse 60’s , 70’s #23
yea I have a 44 Slant Dash All Fuel, its not very healthy - debating whether to put it back stock or add upgraded carb and pistons for more compression and ultimately more power - I don't plan to make it a museum piece and its always nice to have another usable tractor so I don't have to switch implements so much - it will be a winter project one of these yrs......just no time right now this winter is already tied up!!!
I still have the B I grew up on as well. They are torque monsters for sure - I don't like them for an all day work tractor but they are reliable for the most part and not that bad on fuel until you get into the bigger gassers. Couldn't be any worse than a 706 or 806 gasser they guzzled when pulling hard.
I know a 730 D and 830 could pull a 15' batwing but lord knows I wouldn't want to ride one all day pulling it ;-)
/ Old work horse 60’s , 70’s #24
I'm helping clean up liners and pistons out of a JD 5020 . One hole weights more all 4 of my sleeves rods and pistons in our 1948 B Allis Chambers that got the Liquid Glass stop leak ran in the crankcase.
This is the first 5030 I have seen and hope to hear both tractors running soon.
/ Old work horse 60’s , 70’s #26
I put in a day on a 5020 about 30 years ago. Loudest tractor I ever sat on. Pulled good though.
My favorite was my dad's 930 Case diesel. TractorData lists them at 80 hp or so if I recall. It kept pace on a 5-16 plow with the neighbor's Deutz that was rated at 110. It went on auction back in '95 and I've longed for it ever since.
He had a 3pt 18 foot wide field cultivator on it and it would pull it just about anywhere. One time they were cleaning out an old grove to replant a nice tree line at church. He had duals on it with the cultivator mounted. They hooked up a heavy 1" cable around a monster cottonwood stump. There was a 6 foot loop at the end of the cable where they hooked the clevis. He put it in 2nd gear and gave it a tug. The front wheels came up and it balanced about 12k lbs on the rear axles and spun out. The cable clamps slid up the cable with a shower of sparks like a kid's 4th of July sparkler. Another farmer came up behind with his Farmall 460 and started to push with his bucket and the stump moved. They had to get wrenches to unbolt the clamps in order to get the clevis back off though. There are lots of bigger tractors, but I loved the sound of that 6 cylinder snort, and it punched way above it's class.
I got a guy with a jd 4020 that wants me to buy it . Jd 4020 vs case 930 what your thoughts ?
/ Old work horse 60’s , 70’s #28
4020 easier for parts/repairs you might be hard pressed to find a good case repairman? and presuming the 4020 is diesel as is the case?
/ Old work horse 60’s , 70’s #29
Will he sell it at the price of a Case 930?
Both tractors are in about the same condition the case probably in a little better shape. Case is 3500$ John Deere is 6500$. I will be doing the repairs either or.
/ Old work horse 60’s , 70’s #31
The better shape 930 Case is looking better and better. :) I know a guy looking at a $7K bill to replace clutch packs in a 4020 that ran it 10 gallons low on fluid from a leak over time. I do not know the complexity of the Case.
/ Old work horse 60’s , 70’s #32
I've got a diesel 730 Case Comfort King, 1966 model. I am the second owner. Has about 4000 hours. I put a Westendorf loader on it, and it weighs enough to do some work. Easy on fuel, and virtually no repairs required.
Have a Deutz 6206 that is a bit lighter, air cooled diesel, REAL economical, differential lock. Use them both for haying, and mowing pasture.
/ Old work horse 60’s , 70’s #33
well heck if you are a repairman then the 930 seems like a no brainer - they sound like a good tractor - never been around one - I know the next gen 870/970/1070 my cousin swears by but he has had issues getting someone to work on the power shift - he tried fixing his 970 and still has some kind of issue with not all ranges/gears working - thinks he pinched an oring on reassembly so he just uses the gears that work ;-) the engines I have heard are bulletproof pretty much.
/ Old work horse 60’s , 70’s #34
Those old Case tractors were beauties - they had real stye. Although here in the Western US there are more resources for older JDs and that keeps their used price higher.
It sounds to me like you are looking at two excellent old tractors.
If it was me trying to decide, I'd go with whichever one is in the best shape/has had the best care. I don't mean things like tire condition, but rather owner care. It might come down to something like maintenance records/one owner/pride of ownership.
If knew there was something about those JD transmissions that I should have remembered, so I looked them up. The JD 4020 came with either of two types of transmission. The basic was a 4 range standard shift transmission with clutchless High/low on each range.
The other was a completely clutchless powershift with 4 reverse gears. I would guess it was the powershift that had clutch packs since that is how most powershifts work. What I remember now is that both of those transmissions represented a huge dashboard change from the older lever-shifts.
rScotty
A little off of what I’m looking for MF 1080 come up for sale for a good price . Any one have good or bad thoughts about them ?
/ Old work horse 60’s , 70’s #36
here is some reading for you
MF 1:D history and problems - Massey Harris & Massey Ferguson
quoted from redtractorforum.com
on the 1080/1085
I worked for a MF dealer for a little while, and I got tired of working on 10xx series MF's! We had a LOT of clutch problems out of them, and the hydraulics were...well pretty much junk. The perkins motors maybe decent on fuel, but they make up for it in oil leaks. You've heard of Detroits leaking oil? These little perkins can give them a run for their money. The smaller tractors(10xx series) were not, and as far as Im concerned are not worth there weight in gold. The ones around here are used only for haying and bush hogging. So heres what I think about them...
Slow hydraulics
Oil/fuel leaking 4 cylinder engines
Low torque rise
Weak clutch
Pisspoor cab
Over weight and underpowered.
Now as far as the 11xx series, they seem to be pretty solid. They dont have the best hydraulics, but will get the job done. Again, they have the oil leaking perkins. We had alot of problems out the pto's on the these, and many other MF tractors.
Around here you can buy a 10xx MF with cab for about 5K, and an 11xx for about 7 or 8k.
Also, there Multi-power's are pretty much a t/a in an IH, just not as good, and they are pretty expensive to put in.
If I were you, and needed a cheap tractor I too would lean toward an Allis. The MF dealer was also an AC dealer, and we had alot better luck out of them.
The 180/185 were pretty much bullet proof. They used the D301, which is the same engine used in the 190's, 200's, 7000's, 7010's, and 7020's. The only difference in engines between models, were N/A, turbo, or turbo and intercooled. The 185 offers you large frame performance in a small frame package. They have ok hdraulics, hyd. 2 speed(power directer) and hyd pto clutch.
If you want a row crop tractor with a decent cab, I would go for a 200 or 7000. I ran a 200 for quite a few years, and really liked that tractor, but it just got to small for my operation. A 7000 is a 200 in the 7000 series sheet metal. But it does have the Accoustic Cab on it,unless you get a black belly(only made one from 78-79) then it has the Accoustic Cab II. Those a really quite cabs but not for some one's that cluasterphobic. If you have any more questions feel free to PM me and Ill try and answere them as best as I can.
I basically searched google for 1080 MF reviews and that is where this info came from
lots more to read but from my quick look, sounds like there are other masseys that would be much better choices if you are looking to go massey - I have heard the White 2-85s are good tractors they have a 3 speed partial power shift in them, my friend has a white 2-105 and I think it has been a descent tractor its just been abused and not cared for well -
INSPECTION (A61165)
INSPECTION (A61165)
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
Deere 335P (A53317)
Deere 335P (A53317)
2020 CATERPILLAR D6 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
