rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,663
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
The rule of thumb is that a tractor is supposed to weigh at least as much as the baler. A 4x4 or 4x5 dry hay round baler generally weighs less than 5000 pounds with a full bale in the chamber. A smaller cabbed MFWD utility tractor with a loader is going to weigh at least 8500 pounds, and properly ballasted will weigh about five tons. That is more than enough weight.
If you are looking at a cabbed MFWD tractor with a hydraulic reverser, you are pretty much limited to units made since the early to mid 1990s and newer. If you are looking at green tractors, the 5500, 5510, 5520, 5525, 5093E/5101E would fit the size and feature requirements. I've run the "fuel turned down one notch but otherwise identical" versions of the 5510 and 5093E/5101E and they were nice units. If you are looking at pre-Tier 4 units, you want to get one made before 2014- all of the models I listed were pre-Tier 4.
I went the one-tractor route with a 75 HP 2WD open station unit to hay about twice as much ground as you intend on haying someday. I make small squares for myself and sell some, and roll up the remainder in round bales which I load when I sell. I can't say I ever thought I needed a second tractor, as it's just me working and I can't drive two tractors at once and this one is good sized for what I do. All of my hay equipment is drawn so it's easy to drop one piece of equipment and hook up another, it's not like I have a 3 point mounted disc mower that's "fun" to hook and unhook.
Yes, I'd agree with that for haying in the South. I prefer open station myself.... but then I was raised before cabs were common. I do like those JDs.
From the title of the thread I thought the OP was talking beef production - but then he seemed to stray into hay. The work is a bit different. I just don't know about an open station 2wd for doing chores in blizzards & snow . after all, he's in NY.- uh, actually I guess I do know. I've just almost managed to forget what it's like to be bundled up, running chains on duallys and chipping ice.
Summertime is nice, but half the year he is going to be slick, sloppy, and cold.
Maybe a alternative idea is to concentrate on either beef or hay at first, not both.
rScotty
