Notch Master
/ Notch Master #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Tried this out yesterday, great tool.. first couple cuts here to make legs for a tripod to hold it. I set it on 50*, the max, and cut the other end 40* flat on the bandsaw for the feet. I think it's going to come in handy as a pipe vise too, for holding stuff in general. :thumbsup: 2" sched 40 (?) 2 1/2" hole saw.
/ Notch Master #2
That is really nice cut!
I wish I could come up with more projects with pipe / tube. Been waiting for an excuse to buy a tube bender that will bend 180 degrees. Then of course I'd have to have a notcher as well:D. For now I just use the mil.
/ Notch Master #3
That looks like a quality tool! Nice.
James K0UA
/ Notch Master #4
That things nice! I can see that being really nice for working with pipe. Sure beats trying to fish mouth tube with an angle grinder...
/ Notch Master
$8 for a 46" scrap of 1 1/2" sched 80, or $75 for a length, I went with the scrap. The old steam pipe I got for free..
/ Notch Master #6
So you needed the tube notcher to build the stand for the tube notcher!:laughing:
How come you didn't Tig weld those joints? I see a Tig torch in the background of one of your pictures.
/ Notch Master
I'm gonna sell that thing, got no business owning one. :laughing:
Guess I'll make a base for my vise tomorrow. That'll be handy too, drop it in the same tripod. I'll try to be pro, tho, and weld the bolts on the other side.
/ Notch Master #9
/ Notch Master #10
You'll need to get a Tig Rig one of these days, now that you have a DC welder. ;)
/ Notch Master #11
If only that didnt cost so much. The reg and torch are not too bad, it is the tank that is the issue.
/ Notch Master #12
It is strange how in different places the tanks are a PITA! I own all my tanks, well I have a leased 330 cf bottle of 90/10 right now to just play with some spray arc. But the tanks I own, I never get the same tank back. All I have to do is make sure the kid doesn't give me a tank without a "P" on it. I don't have to pay for testing either.
/ Notch Master #13
I think it is the same here. I own my O/A tanks. I will have to check how much an argon tank will cost me. I would likely buy a small one. (40cf ish)
/ Notch Master #14
Tig welding steel and stainless steel, you can run your argon bottle down to nothing, but welding aluminum when the bottle gets low it will mess up your weld. So when doing aluminum work a bigger bottle is nice, because you're not going to get all the argon out.
/ Notch Master #15
Well with my dc only, I dont think I will really have to worry about aluminum for now. :laughing::thumbsup: Unless I rig up high freq for my tombstone.....
/ Notch Master #16
Oh, you can do it old school, DC with helium. Here's one I did years ago.
/ Notch Master #17
I hear due to the shortage the pure helium you need for that costs an arm and a leg. It doesnt really matter to me, I almost never work with aluminum. In the rare case I do need to join aluminum, I could just get some of those aluminum brazing rods.
/ Notch Master #18
I do a lot of tube notching for roll cages in race cars. That is one verry nice notcher. A lot better than my old Jointjigger. Where did you get it from. Milwaukee has some hole saws that are called ICE. I have had great luck with them. They last a lot longer than a standard bi metal hole saw.
Bill
/ Notch Master
Exactly what I was thinking. They say the success of a mans life is measured by how many tools he has at his death. :confused:
I was just kidding about selling it, first couple tries were not very successful. :eek:
It's probably gonna be more time consuming with the practice than I can devote to it, to learn it right anyway, I'll just plod along with it when I can.
/ Notch Master
Bill, I got it right from their website JD2.com
2013 TIGERCAT 720E FELLER BUNCHER (A65056)
2013 TIGERCAT 720E...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
2018 FORD F-250 SUPER DUTY PLATINUM (A67714)
2018 FORD F-250...
YALE FORKLIFT (A63291)
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
