jayste
Veteran Member
- Joined
- Feb 12, 2008
- Messages
- 1,744
- Tractor
- 2004 Kubota M4800 SU
I've pulled several and it wasn't too bad if you have some help. I've seen the folks that are in the business have a (1 ton) truck mounted crain to assist them and I've heard of the method I've used as well which is a couple of wide shouldered country boys method...well, in my case it's me and another country boy who happens to have wider shoulders!
Anyway, it can be done with a 280' well. CurlyDave mentioned not dropping it and that is important but all of the wells around here have a "well rope" tied on to the pump and tied off at the top for just that purpose of not dropping it back in the hole. Poly-something-or-rather or commonly called "ski rope" is used for this. I guess it will last longer than most in these kind of conditions. As far as the 12-4 wire issue all "pump wire" I've used is either 12-3 or 12-4 and all conductors are "sheathed" including the ground. 12-4 being used if your control switch (not to be confused with the pressure switch) is at the pump and not top side with the pressure tank and pressure switch. I've got two wells and they are of each type. One has a top side control switch and the other has the control switch at the pump in the hole. Anyway, just sharing a little experience.
Also, something that comes to mind that is similar to the "original problem" of this thread is with pressure and flow in the house. Occasionally I will have a situation where while taking a shower or running water in general the pressure will slowly decrease to the point where no water flows for a couple of seconds and then comes back on. When this happens I've found the problem to be in the 1/4" nipple underneath the pressure switch. Originally, I replaced the pressure switch thinking that the problem was there but that didn't do anything but replace my old ugly switch with a new shiny one and cost me around $20!
I've found that by removing the switch and taking off the nipple and cleaning out the nipple of build-up of minerals (a nice way of saying crap in the nipple) then all is back to normal.
I hope all this rambling helps clear up a few questions that you might have or save you some headache the next well problem you have.
Jay
Jay
