No electric: Alternatives?
/ No electric: Alternatives? #21
12 years ago my wife and I bought a non operational farm outside Ironton Ohio. We moved there thinking it would be for the better. As it was, mid 91 -92, I cna't remember a single day that it did not rain within a 24 hour period. Talk about depressed!! And those people haven't a clue what snow is. Something I need to see frequently. Anyway, the person we bought that farm from ahd the same set up as you Slippy. What he did was to convince Ashland oil to test bore for natural gas and maybe a little oil. They had to make the roads (which ended up being many overgrown cart paths) for them to tests. BTW, it was determined not enough gas/oil for them to pursue it. We were the only ones on that long country road that owned the mineral rights to the property. You may consider soemthing like this if gas/oil are in your area. It was quite common not to many years ago to see the wells all over that area and across the river in W.VA on various farms.
/ No electric: Alternatives? #22
Wow. I thought Rural Living was just a link that took me to CountrybyNet forum. It's a whole separate forum! I found your "Off Grid" thread and a whole bunch of other interesting stuff. I'm going to be busy for a while looking through all this...
As an aside: Solar's come a long way in the last few years. The most intriguing thing I've seen lately is the metal roofing that's also a solar panel. If you're building new, this might be something to consider. But it all depends on your needs. If you just need to hook up a drill once in a while, or much more.
/ No electric: Alternatives? #23
There are also solar powered well pumps. I haven't looked into. But I remember a trip to Oklahoma last year. It was funny driving down farm roads and seeing the old wooden windmill frames. And sitting at the top, instead of fan blades, was a little solar panel.
/ No electric: Alternatives? #24
Another option he can think of is a 12v well pump...
And as you say.. a small engine running a generator, or even one of those fance 120vac alternators I have seen for RV's.
Still thinking about that pto genny might be a good idea if they have a tractor.
Soundguy
/ No electric: Alternatives? #25
Only problem w/ PTO generators is having to run tractor at high RPM to get the proper voltage (unless two speed PTO like 1000 and 540) or build his own w/more gear reduction so he could run engine slower.
I have a 40K Generac PTO gen set on a trailer but power hasn't gone out since I got it in fall 1999 /forums/images/graemlins/smile.gif
/ No electric: Alternatives? #26
</font><font color="blue" class="small">( I have a 40K Generac PTO gen set on a trailer but power hasn't gone out since I got it in fall 1999 /forums/images/graemlins/smile.gif )</font>
Fall of 1999 - Why2k did you buy it at that time? /forums/images/graemlins/grin.gif
/ No electric: Alternatives? #27
I don't see how running the tractor at 540 rpm pto speed is a real problem..... it is designed to be run at that speed and under load... heavy load. Other than the noise of the tractor??? Or are you talking about just having power on all day.. and not wanting to run the tractor that long?
Soundguy
/ No electric: Alternatives? #28
Slippy,
another gen set to consider is the Winco . www.wincogen.com
They're about as reliable as an anvil . Try as we might we haven't had one let us down. And ,God knows we've had some folks try to kill it . ( fed it bad fuel,haven't checked the oil ,etc.... )But it always runs ! we have a couple that run all day, most everyday .The Northern gens are also good if you go for their industrial gens . If you are looking for a long term/run gen , go for a deisel unit that runs at 1800 rpm . Quiet and a long runing unit . JMHO. John
/ No electric: Alternatives? #30
If you want a diesel generator close to this size, one possibility to look at is a Engine Driven Welder/Generator. For about the same price as a generator you get a big welder too.
A Miller Bobcat 250 D NT has a street price about $5700. It uses a 19 HP Kubota engine and can produce 9,500 Watts continuous and 10,000 Watts peak. Its the cheepest Kubota diesel powered generators I have seen. You get 275 Amp Stick and MIG (by adding a spoolgun) welding capability as a bonus.
The Trailblazer 301 D adds AC/DC TIG capability and increases the welding current (but no more generator capacity) for an additional $700 on the street price.
The Gasoline welder/generators use Onan or Kohler engines and also look like good values.
See Miller generator overview web page.
Bobcat 250 D NT
Trailblazer 301 D
DeDekker: What an interesting idea. I don't know a thing about welding, but who cares. I have been looking at a PoweTech diesel gen, used for RV. The cost of a 7000KW is about 6K. I will check in to the Miller gen/welder, but do you know if these things are designed to run all day like a reg gen is?
/ No electric: Alternatives? #32
Portable welders are made to use for long runs and the one w/ Kubota diesel should be water cooled and long life span.
/ No electric: Alternatives? #33
I would expect that an engine driven welder/generator in the Bobcat/Trailblazer/Trailblazer Pro class would be far more durable than a RV generator. The welder/Generator is a piece of equipment placed on a welding truck or on a job site. Some job sites are remote and access is difficult (most pipeline work). On a job site (e.g. building construction or pipeline) the welder will be used one to three shifts each day to provide power as well as weld metal, potentially all year. The owner of the welder/generator will lose serious money if the Welder does not work. Miller (or Lincoln the other major company) would get a bad reputation quickly if the welder/generators did not hold up. The engines used are the best commercial duty engines available in the size used, Kohler and Onan gas engines and Kubota diesel engines. (The BIG Miller units use CAT, Perkins and Deutz diesels but these are very expensive and have less capacity as a generator.)
I would expect the typical RV annual use to be a few weekends plus one month in the summer and I would expect that the RV generators to be designed accordingly.
From this comparison I would expect a far longer life for the welder/generator than the RV generator.
When something does go wrong you will need repairs. Will you do repairs yourself? (I assume you will do maintenance yourself.) With the Miller (or Lincoln) you can be assured that local service is available for the generator. In any case long term you will need replacement parts. Parts will be available for many years for both the engine and generator.
I looked at the online copy of the manuals for these welders and could not find a rated Mean Time Between Failures, Mean time Between Engine Overhaul, or a number for the expected hours of operation per month.
The question of machine durability and life span would be a good question for Miller and one of the forums where more professional welders hang out. These include: the newsgroup sci.engr.joining.welding and the website Hobart Welding Talk Message Board (Hobart is a sister company to Miller. Both are owned by ITW. The moderators work for both Miller and Hobart. )
I did see one issue (which the RV generator will share). Like our tractors, engines in this class are rated for oil changes every 75 hours (Bobcat and Trailblazer) to 200 hours (Trailblazer Pro). You could probably stretch this a bit by using a good synthetic oil since you will be running is a low dust environment (compared to the construction site).
You mentioned 'run all day' in your last message. How much do you anticipate running the generator?
Running all day occasionally will not be a problem but if you want to run all day every day any small engine driven generator will be expensive.
First you will have routine maintenance, just changing the oil every 3 days or even once a week would be a pain.
You will also need to consider the engine Mean Time Between Overhauls (and engine life) . A MTBO of 4000 hours (or an extreme of 10,000 hours) sounds like a lot for a compact tractor. But for a generator running 24 hours a day by 7 days a week, 2000 hours is only 166 days (5 1/2 months) and the extreme 10,000 hours engine life is 416 days (13 months).
(Compare that to a car engine. A car engine which lasts 200,000 miles without major work is doing pretty good. 200,000 miles at an average 50 miles an hour is 4000 hours.)
Ed: thanks for the additional info. Have you heard of Lister-Petter generators? They have a web site and claim the life expectancy of their gen are 12-30,000 hours. Claim gen engines made in Japan will only last up to 15K hours. Has anyone ever heard of these? Also, on the welder gen, it does not make sense to me that you can buy a welder gen for less money and more watts than a plan generator. I have also learned that some gen are 1 phase. Others or 2 or 3 phase, which I understand is helpfull in start of of electric motor type
applications. As far as how much it will be run; it will run all day on weekends, a couple of times a month. In the hot summer days, may want to put in small window airconditioner. I want folks inside to be comfortable.
/ No electric: Alternatives? #35
I know nothing about Lister-Petter except what I found on the web today.
e.g.
web page 1
web page 2
web page 3
A google newsgroup search for Lister-Petter shows most comments on the companies generators are from the UK. What is the parts availability in Ohio?
The Lister-Petter engine is 1800 RPM which is good for a long life. The life of a slow speed diesel will be better (for long engine life) than the life of a high speed (3600 RPM) diesel engine, which in turn is better than a 1800 RPM gasoline engine and on down to a 3600 RPM gasoline engine. I see that Lister-Petter has a long history of making marine diesel engines (good again).
I still have problems with the claim of 12,000 to 30,000 hours between overhauls. 30,000 hours is 1250 days or 3 and a half years of near continuous operation. I am skeptical of this. I don't have experience with any motor with this kind of life, or with a slow speed diesel engine. Since I don't have direct experience with this type engine I compare it to something I am familiar with, a car engine. Using the car analogy, at 50 Miles an hour this would be 1,500,000 miles. This is possible for a rare exceptional car engine, exceptionably well maintained, but not for an average figure. Second what are they claiming with the range 12,000 or 30,000? That is an extremely large range, more than a factor of two. I would read that as the lower figure, the minimum they claim for their generator. A failure at 12,001 hour would meet the published specs. So the lower figure is all they are really claiming. (Still seems high to me but it is closer to reality.)
With all the moving parts in the diesel engine these numbers just 'feel' too high. We start off with the injection pump, a mechanical high pressure pump which must spray fuel into the cylinder at maximum compression. We have many bearings (on the crankshaft, the cam shaft, both ends of the connecting rod, cam shaft ...). Sliding friction between the piston rings and cylinder walls, in the valve guides ...). There are things that can just break or burn, valve guides, lubrication passages to clog, timing belts to slip or break, gear teeth to break, ... There are just too many places with metal rubbing on metal for nothing to get out of spec in 10,000 to 30,000 hours. The only way I see to spec a MTBO this long is to define a very lose fit, much loser than new, as acceptable, and hope that nothing actually breaks or burns.
(Please anyone am I am off base here?)
There are generator technologies with the potential for extremely long life. The Capstone MicroTurbine microturbine.com is capable of a MTBO and MTBF exceeding 100,000 hours. It uses a small turbine engine with air bearings so it has one moving part, and no metal to metal friction. The first scheduled maintenance is at 8000 hours, an air filter change. At 30 KW and up it is above the power range we have talked about. The price is above the price range we are talking about by an order of magnitude. (I did see one Capstone on ebay last year, new, never uncrated, with no reserve, no bids, a starting price of $9,000, and the auction about to end. At the time I considered getting it as the ultimate back up generator for my house (or to resell for a big profit) but ended up decided that it just sounded too good to be true, and there was no time to check out the seller. )
If forced to come up with an explanation for the price of the Miller welder/generators, I would explain that the welder price situation is the way it is because the market for Generators has been separate from the market for Engine driven welders with auxiliary power output. The prices have been set, over a long time, based on competitive pressures within their own markets. The prices tell us that the Welder market has been more competitive, keeping the prices down, and demanding high reliability. Miller (given the generators page on their web site) has realized that there is an opportunity to sell to the other market is now actively attempting to sell into the generator market. Miller is limited by its distribution system, most generator purchasers still do not think to check Miller before buying, and the retail level in Millers distribution chain, welding stores are not exactly pushing for new markets, or friendly to anyone walking in the store who will not buy 1000 pounds of electrode a month.
In addition, the Miller units have a big disadvantage for most users of portable generators, weight. The Bobcat and Trailblazer weigh about 600 pounds and the trailblazer pro weighs over 900 pounds. This would not matter to you, you are comparing it to a stationary generator (among others). But someone looking at a PORTABLE generator will compare the Miller to a Honda or even a Northstar 6000 Watt generator at about 300 pounds. Even a 10.5 KW Commercial duty Honda gasoline generator only weighs 400 pounds.
If it will be moved by hand 600 pounds 'is' (seems to be) at least 4 times as heavy as 300 pounds. (On the other hand there is Mashburn's law of quality: Shipping weight is a direct measure of quality when comparing two items of the same type. Heavy items are better with bigger beefy parts, therefore higher weight in the item. Light precision items benefit from big beefy shipping containers, therefore more weight in the packaging materials.)
Three phase power is a whole other can of worms.
There is no 2 phase power system in common use. Single phase power is two legs (wires) of the three phase power. Adding one wire gives us three phase. Think of the phase as the voltage difference between each pair of wires. Three wires A B and C give us phases AB AC and BC. A single phase service is only one of the pairs, any one one of the pairs. Presumably the other two pairs provide electrical power to others with single phase service to balance the load to the generator. In addition to the two (single phase) or three hot wires (three phase) there is a ground. The phase of the 60 Hz voltage on each of the three wires is phase shifted by 120 degrees relative to the other two wires. (360 degrees being one complete cycle of the sine wave.)
Basically you would already know if you needed three phase. Power distribution, industrial equipment, and big motors are three phase. Three phase motors are usually more efficient and split the power required over the three input wires. This lowers the current flowing through each wire and therefore the size needed for each conductor. Three phase motors can be reversed trivially, with a simple switch, by exchanging any two of the 3 input power wires.
In the US household power is single phase with a center tapped ground. The distribution system is three phase. The two hot legs give 240 volts between each other and 120 volts from each hot leg to ground. At the service entry (and only at the service entry) the household Neutral is bonded to ground. The Neutral serves as the return for 120 Volt power. In The US both 240 and 480 volt three Phase power is used, depending on the requirements and availability. The three phase can be converted between 240 Volts and 480 volts by three phase transformers. (I will stop here and not get into the differences between delta and wye ('Y') three phase. Believe me, you do not want to know.)
In the US most residential areas are not wired to provide three phase power. (My next door neighbor considered building a pole barn for his woodworking business but found that he would have to pay for something like many miles of power line to get three phase power. The cost would have been far more than the pole barn.)
You would need 3 phase power if you were planning to have large electric motors over about 8 horsepower (real horsepower not Sears horsepower). In a workshop this would typically be on serious metalworking or woodworking machines. A Bridgeport mill could have either a single or three phase motor while a bigger vertical mill will almost always have a three phase motor.
Hobbyists and small shops which do not have a three phase feed from the power company and have (smallish) tools which require three phase can generate the three phase power for specific tools with a phase converter. A simple phase converter is just a three phase electric motor driven with the two hot legs from the power company acting as a generator to generate the missing leg (this works with some inefficiency). A far more complex technique is a VFD (Variable Frequency Drive), this is a more modern solution. A VFD is a solid state device which produces true three phase at a selected frequency. By changing the frequency 'slightly' from 60 Hz the speed of the motor can be changed. (The speed of a three phase motor is determined by the frequency of the power.) In general terms the machines which would need three phase would need more than 7 to 10 KW of power, more than can be powered by the generators we are talking about. (A 10 HP motor can use 47 KW to start and 11 KW to run. A 5 HP motor can require 23KW and 7KW.)
One of the Miller Gasoline welder/generators offers 480 Volt three phase power output, but at 9.5 KW output its not big enough to start the really interesting machines. (Eastec is coming up in May, so I will get to see some of the big stuff soon.)
/ No electric: Alternatives? #36
>>Some PARANOID people I work w
You bought a 40KW generator in the fall of 1999 and have 20,000 gallons of diesel on hand...and you are calling them paranoid??? /forums/images/graemlins/confused.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ No electric: Alternatives? #37
You mention a fridge and clock. If you want to power them, you will require power 24x7, and I think you'll find a generator prohibitive for that. You might consider propane for the fridge and a battery clock, thenyou can just run the generator whenyou are actively using the barn.
/ No electric: Alternatives? #39
I own a construction company plus farm 100+ acres and always fill tanks in fall before winter hi price heating oil.
Only 2,000 gal not 20,000 gallons.
Tanks should be empty in a month or so, $$$$$$$$ for this refill.
A 40 K gen set (like new)for $1500 is a deal I couldn't pass up and some jobs we need lots of power and no utilities for months.
I've got a 3500w and 6000w generators too.
Plus a 16hp Lincoln portable welder.
I do keep 300 gal. of gas around too but is usually goes in wifes car /forums/images/graemlins/frown.gif
7' Disc (A62613)
7' Disc (A62613)
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
Titan Attachments Forks (A64126)
Titan Attachments...
2017 Case CX145D (A60462)
2017 Case CX145D...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
