NH T1510 Steering Problem
   / NH T1510 Steering Problem #11
Changing oil and filter won’t fix tractor. Are you sure it don’t have a separate tank and pump for the steering?
Can’t see what 17 is on parts list.
Will this help?
   / NH T1510 Steering Problem #16
No you don’t check or fill there. It’s either the transaxle or separate tank. That appears to be the steering valve.
Is there a way to bleed out the system? Wondering if there might be air somewhere in there. Seems like the only place to check for hydraulic fluid is on the dip stick.
   / NH T1510 Steering Problem #18
Again, going back to my post #7. I referred to the rubber hose, which connects the front steering pump to the rear hydraulics pump. This hose is the weakest link in this system, if there is a restriction from the transaxle reservoir to the pumps. It will collapse and restrict flow to the steering pump. Flow can be restricted a number of ways, including: restriction of flow to the filter in the transaxle, filter restriction, or collapsed steel line from the filter to the pumps. Most likely- filter restriction. Drain the tranny, change the filter and watch for rubber hose collapse. If the filter change solves the problem, I would still consider changing the rubber hose as I said, it is the weakest link in the steering system.
Thanks. I came out to the garage to check some things. Main thing I notice is that whenever the steering gives me issues it makes a noise, kind of like a loud higher pitched humming sound. It also does it every time I raise the 5ft brush hog. Won’t do it when I lower it. Sounds like it’s coming from the area circled in red. Looked on messicks but didn’t see that part. I’m almost certain it shouldn’t be making that noise.
I checked all the lines and hoses and don’t see anything wrong.
f83dd963-4ca8-42c1-a8d3-61ded6a4ced3-jpeg.764232
   / NH T1510 Steering Problem #20
Are there any belts to check??
willy
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
