NH T1510 Steering Problem
   / NH T1510 Steering Problem #11
Changing oil and filter won’t fix tractor. Are you sure it don’t have a separate tank and pump for the steering?
Can’t see what 17 is on parts list.
Will this help?
   / NH T1510 Steering Problem #16
No you don’t check or fill there. It’s either the transaxle or separate tank. That appears to be the steering valve.
Is there a way to bleed out the system? Wondering if there might be air somewhere in there. Seems like the only place to check for hydraulic fluid is on the dip stick.
   / NH T1510 Steering Problem #18
Again, going back to my post #7. I referred to the rubber hose, which connects the front steering pump to the rear hydraulics pump. This hose is the weakest link in this system, if there is a restriction from the transaxle reservoir to the pumps. It will collapse and restrict flow to the steering pump. Flow can be restricted a number of ways, including: restriction of flow to the filter in the transaxle, filter restriction, or collapsed steel line from the filter to the pumps. Most likely- filter restriction. Drain the tranny, change the filter and watch for rubber hose collapse. If the filter change solves the problem, I would still consider changing the rubber hose as I said, it is the weakest link in the steering system.
Thanks. I came out to the garage to check some things. Main thing I notice is that whenever the steering gives me issues it makes a noise, kind of like a loud higher pitched humming sound. It also does it every time I raise the 5ft brush hog. Won’t do it when I lower it. Sounds like it’s coming from the area circled in red. Looked on messicks but didn’t see that part. I’m almost certain it shouldn’t be making that noise.
I checked all the lines and hoses and don’t see anything wrong.
f83dd963-4ca8-42c1-a8d3-61ded6a4ced3-jpeg.764232
   / NH T1510 Steering Problem #20
Are there any belts to check??
willy
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A49461)
2008 Ford F-450...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
