NH 1720 Wants to tip over
   / NH 1720 Wants to tip over #1
VetRick
New Holland 1720
NH 1720 tips dangerously to the right even on level ground. It is a 4WD with a FEL. Problem started a few months back when operating on wet ground while moving hay rounds but has gotten worse to the point that left rear wheel has come off the ground. Now it happens even when there is no load on the loader. Any thoughts on where the problem could be? Wheel, differential, axle? Front axle is on a center pivot pin and there is no discernable leakage or disconnected parts. Thanks! Any help is welcome.
   / NH 1720 Wants to tip over #2
Astounding! Unnaturally twisted. Need pics.
   / NH 1720 Wants to tip over #4
What's the tire air pressure?
   / NH 1720 Wants to tip over #5
Seeing tractor design I have a really hard time understanding your problem.... Maybe tire pressure is about only thing other than bad load balance in FEL...
Might try wheel spacers to widen the rear track for more stability...
   / NH 1720 Wants to tip over #6
Check to see if you have cracked frame as a result of picking up the hay rounds.
   / NH 1720 Wants to tip over #7
It would be very interesting to see a video of both sides with this happening.
   / NH 1720 Wants to tip over #8
I would be inclined to maintain a comfortable distance from that tractor.
   / NH 1720 Wants to tip over #10
You mention that it happens with no load. Does that mean it happens just driving straight on level ground or are you maybe making a hard turn. If this happens just driving straight on level ground then I can't even imagine a cause. Do you have a dealer close that you could discuss this with?
   / NH 1720 Wants to tip over #11
Brakes sticking on one side rear can cause this.
   / NH 1720 Wants to tip over #12
Spoof posting?
   / NH 1720 Wants to tip over #13
That doesn’t make sense to almost tip with no load??
Are you operating with loader raised to see under it??
   / NH 1720 Wants to tip over #14
First thing that came to me was he main frame is flexing or broken.
   / NH 1720 Wants to tip over #15
You have a broken frame or an attachment has come loose or possibly you have no ballast in that rear tire.
Don't use it until problem found, find someone knowledgeable to look at it.
   / NH 1720 Wants to tip over #16
Just an observation:
It appears Mr. VetRick joined TBN on 10/10/25 and the post starting this thread was his first and only post...with no response since.
   / NH 1720 Wants to tip over #17
Possible that he's gone for the weekend or is just a flake or doesn't know how to find replies.
   / NH 1720 Wants to tip over #19
It isn't uncommon for somebody searching the internet for help to join, post his question and never come back. Quite likely he has done the same on several other forums.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
KUBOTA L2501 TRACTOR (A60430)
KUBOTA L2501...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
