NH 1720 Wants to tip over
   / NH 1720 Wants to tip over #1
VetRick
New Holland 1720
NH 1720 tips dangerously to the right even on level ground. It is a 4WD with a FEL. Problem started a few months back when operating on wet ground while moving hay rounds but has gotten worse to the point that left rear wheel has come off the ground. Now it happens even when there is no load on the loader. Any thoughts on where the problem could be? Wheel, differential, axle? Front axle is on a center pivot pin and there is no discernable leakage or disconnected parts. Thanks! Any help is welcome.
   / NH 1720 Wants to tip over #2
Astounding! Unnaturally twisted. Need pics.
   / NH 1720 Wants to tip over #5
Seeing tractor design I have a really hard time understanding your problem.... Maybe tire pressure is abou only thing other than bad load balance in FEL...
Might try wheel spacers to widen the rear track for more stability...
   / NH 1720 Wants to tip over #6
Check to see if you have cracked frame as a result of picking up the hay rounds.
   / NH 1720 Wants to tip over #7
It would be very interesting to see a video of both sides with this happening.
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2000 Ford F-150...
Pallet of Fluorescent Traffic Cones (A55787)
Pallet of...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
