NH 1720 Wants to tip over
   / NH 1720 Wants to tip over #1
VetRick
New Holland 1720
NH 1720 tips dangerously to the right even on level ground. It is a 4WD with a FEL. Problem started a few months back when operating on wet ground while moving hay rounds but has gotten worse to the point that left rear wheel has come off the ground. Now it happens even when there is no load on the loader. Any thoughts on where the problem could be? Wheel, differential, axle? Front axle is on a center pivot pin and there is no discernable leakage or disconnected parts. Thanks! Any help is welcome.
   / NH 1720 Wants to tip over #2
Astounding! Unnaturally twisted. Need pics.
   / NH 1720 Wants to tip over #5
Seeing tractor design I have a really hard time understanding your problem.... Maybe tire pressure is about only thing other than bad load balance in FEL...
Might try wheel spacers to widen the rear track for more stability...
   / NH 1720 Wants to tip over #6
Check to see if you have cracked frame as a result of picking up the hay rounds.
   / NH 1720 Wants to tip over #7
It would be very interesting to see a video of both sides with this happening.
   / NH 1720 Wants to tip over #8
I would be inclined to maintain a comfortable distance from that tractor.
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2022 31 MINI SKID GRAPPLE BUCKET (A55745)
2022 31 MINI SKID...
Metal Storage Box (A47477)
Metal Storage Box...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
United 5' 3pt. Box Blade (A50775)
United 5' 3pt. Box...
