NEW XR4145C with Issue
   / NEW XR4145C with Issue #21
Doing the math for the 16cc pump it comes out to be a 11 gpm pump. So I can see why it would be pretty fast.
   / NEW XR4145C with Issue #22
They have it listed as 10.6gpm but don't specify how they determined that rating. The drive ratio is 40:39(40 teeth on the crank and 39 on the pump drive gear) which I believe with the engine at the rated 2,600 rpm would put the pump speed at ~2,666. A 98% volumeteric efficiency would put it pretty much right at 11gpm as you specified. Perhaps they are being conservative in the rating? I don't have a flow meter or I would verify the output on mine.
I'm very happy with the speed but I have thousands of hours of experience(almost 1,000 hours on this specific tractor). I also have 800lb of ballast in the rear tires and typically have a heavy duty blade on my 3pt. I would just suggest less experienced operators use some extra caution when they first install an upgrade like this.
I spoke with the manufacture of the FEL control valve for the LS XR, Walvoil USA, out of Utah I believe. Took a bunch of digging to find the actual manufacture of that valve. They make two control valves for that will be a direct replacement for the LS XR41xx, one that comes with the tractor and one that has the serial regeneration and float. I heard back from a rep who gave me the run around for a while before passing me off to another rep who has yet to return my phone calls or emails. All I want is one of those valves!
   / NEW XR4145C with Issue #24
I spoke with the manufacture of the hydraulic pump for the LS XR, Walvoil USA, out of Utah I believe. Took a bunch of digging to find the actual manufacture of that pump. They make two pumps for that will be a direct replacement for the LS XR41xx, one that comes with the tractor and one that has the serial regeneration and float. I heard back from a rep who gave me the run around for a while before passing me off to another rep who has yet to return my phone calls or emails. All I want is one of those pumps!
Are you talking pump or loader scv? Sounds like you are talking about the scv.
SCV. Sorry. I did say pump. :eek:
I was looking to replace the valve, hoping that would fix my issue as well. A better pump would probably do the trick too, but that is a ton more $$.
   / NEW XR4145C with Issue #27
If you find a replacement valve with Regen please share. Maybe a few of us that would be interested.
My search led me to Walviol who apparently makes the valves for LS. I contacted them trying to figure out which one I needed, but got the run around something fierce.
I decided to live with it. Frustrated with it, but then I saw this thread:
https://www.tractorbynet.com/forums...hydraulic-pump-upgrade-deplorable-diesel.html
Apparently, this better pump with mostly eliminate the floppy bucket issue. I havent replaced mine yet, as my tractor is still under warranty and I am positive this will void it. But when that warranty expires... :licking:
I am not sure about the TYM line of tractors.
   / NEW XR4145C with Issue #30
I am not sure what all they did, but getting a new MT342 s-hst cab tractor seems to have fixed my XR4140 floppy bucket issue. Maybe you should just trade in the XR for the new MT version.
I know it has a new loader version and it has a new s-hst pump (if you have s-hst) with some higher flow ratings, but I don't know if that is what fixed it.
I just know my XR4140 had floppy bucket pretty bad. No matter what I did at any RPM it was bad and now its almost not even noticeable on the new one.
I show the bucket movement in this video toward the end: NEW LS Tractor MT342 Overview - YouTube
I tested it by moving some heavy gravel later and the issue still did not show itself. I am keeping my fingers crossed that they figured out a way to minimize it to almost nothing.
405 (A52706)
405 (A52706)
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
Compressor (A55973)
Compressor (A55973)
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
