Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,763
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Well, you’d have to build (4) plates for front and rear pairs of hangers, then you’d have to remove and replace U-bolts. U-bolts are only $50 each. To be honest, my existing U-bolts look pretty scary anyway.I found a couple of old pics I had taken of a tailplate, two 1/2" NPT couplings either side for trailer air, center hole for electrical, bottom holes for a 50T air cushion pintle hitch and of course the D rings. If it's in your budget, the air cushion pintle saves a lot of banging, not cheap tho.
I've got the drawings I had made for subframes but unfortunately I no longer use nor have the software they were created in.
Sure, all you're effectively doing is moving the frame up 3", just treat it like the truck frame. Not saying there' isn't going to be some customizing but I can't see why it wouldn't be minimal.
As long as it's not paper thin and Swiss cheese, the subframe should bridge the bad area. The subframe is running front to back, so with the dump body dumping, the rear of the frame is partially in compression. Yes there is still some vertical load but the subframe will help spread it out.
Ideally yes that would be the cats ass but I don't think much of the idea of moving the hangers out the thickness of the plates.
You think they'll be able to be moved out with no problem with anything clashing?
The lingering question is: Is there a vertical alignment pin on top of the axle tube for the base for the springs? If there is, then what?
Another thought: I am also concerned about the rust spot compromising the frame not just from the standpoint of the dump body, but also the overall strength of the suspension.
I was thinking the inverted L idea-full length of frame from cab to end, would also make the frame appearance really nice (say for resale) nice glossy, smooth looking finish rather than painted over pock-marks????
Like a “2-fer” (strength and appearance).
I’m not overly concerned with weight since the truck is 41,780 GVWR.
You could hang the inverted L on the frame and the top of the frame would be nice & level, to…..even with the rust jacking opening.
