New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
I found a couple of old pics I had taken of a tailplate, two 1/2" NPT couplings either side for trailer air, center hole for electrical, bottom holes for a 50T air cushion pintle hitch and of course the D rings. If it's in your budget, the air cushion pintle saves a lot of banging, not cheap tho.
I've got the drawings I had made for subframes but unfortunately I no longer use nor have the software they were created in.
Sure, all you're effectively doing is moving the frame up 3", just treat it like the truck frame. Not saying there' isn't going to be some customizing but I can't see why it wouldn't be minimal.
As long as it's not paper thin and Swiss cheese, the subframe should bridge the bad area. The subframe is running front to back, so with the dump body dumping, the rear of the frame is partially in compression. Yes there is still some vertical load but the subframe will help spread it out.
Ideally yes that would be the cats ass but I don't think much of the idea of moving the hangers out the thickness of the plates.
You think they'll be able to be moved out with no problem with anything clashing?
Well, you’d have to build (4) plates for front and rear pairs of hangers, then you’d have to remove and replace U-bolts. U-bolts are only $50 each. To be honest, my existing U-bolts look pretty scary anyway.
The lingering question is: Is there a vertical alignment pin on top of the axle tube for the base for the springs? If there is, then what?
Another thought: I am also concerned about the rust spot compromising the frame not just from the standpoint of the dump body, but also the overall strength of the suspension.
I was thinking the inverted L idea-full length of frame from cab to end, would also make the frame appearance really nice (say for resale) nice glossy, smooth looking finish rather than painted over pock-marks????
Like a “2-fer” (strength and appearance).
I’m not overly concerned with weight since the truck is 41,780 GVWR.
You could hang the inverted L on the frame and the top of the frame would be nice & level, to…..even with the rust jacking opening.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #162
Like I had said, go to a dealer and see if the have a new hanger you can look at, only way shy of taking it apart, you're going to know for sure.
How thin is it, any way to tell for sure? I know you had said it was rusty but there's thin.....and holy crap thinnnn.
That's a 12' sheet of plate to have sheared and bent, anyone close to you to do it if you go that route?
The best way I could describe the rusted are is it is inside the 6 bolt area where the rear spring hanger is. It looks like the outer piece of frame is about 50% rusted away. The inner piece of frame is fine. What concerns me is that area is under a lot of stress from the suspension hanger and it being the fulcrum of the the dump hinge/pins.
Maybe I am over-thinking this, but I feel like doing this now would be a lot cheaper than a big “UH-OH” later once the body is mounted.
The truck is at a welding & fab shop. They can build or do just about anything. I do what I can do, and they do the rest. Very nice people to work with.
Here is where the outer frame is thin (red box). A pile of asphalt sat in here for probably years, held in moisture and deeply rusted an area of the frame about the side of a fist.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #164
Ultimately it's your decision, I understand the , "pay me now or pay me later" decision you have to make.
I don't think there's a bad choice other than doing nothing. Looking back at the options we've talked about.....I'm leaning toward the shorten the crossmembers and put a doubler inside the frame.
More info incoming. IH parts diagram does show a pin. :( not surprised.
I may have to reinforce from the inside as you suggest. I would lose the feature of covering the rougher frame with a smoother piece.
It would actually be a “tripler” :)
So I did some more pausing and gathering information on the truck. Spoke with a company in Ohio that installs beds and we got to talking. The guy was very knowledgeable. He spent 20 years in the shop doing frame work and mounting dump bodies on trucks.
What he told me surprised me a bit.
He said he would not bother reinforcing the frame.
He said to cut the last section off of the outer frame that has the rust issue (it’s about 18” long), and simply butt weld a replacement piece in place of it, then put a set of 5/8” bolts on either side of the weld and call it a day.
This would save me a few thousand, but at the same time leave me with a truck with a 12’ dump body.
He suggested if I was on a real low cost budget to buy a 10’ bed and slide the rear axle forward.
They have a 2020 leftover 10’ BiBeau dump bed for $8,200 (normally they are $10,500)
12’ Bibeau dump bed is newer, so it’s $12,000.
So it comes down to about $4,000 more for the extra 2’ of dump bed.
I’m guessing the cost to slide the axle forward is a little more than the cost to butt weld the back pieces on and bolt them.
So here I am. Now I need to decide. I’d really rather have the full 12’, but $4,000 would go a LONG way towards pump, tank, PTO and cab controls……
Shop doesn’t have any 5/16” frame in stock, BUT I have frame on the front of my truck basically unused from when it had the engine driven pump.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #167
From following this from day one and the way you've been talking about a 12' bed, I'd say go the 12' route. If you compromise and shorten up to 10' you're not going to be a happy camper and will regret not going 12' like you've wanted all along. It'll end up..wouldda.......coulda.... shoulda.:)
I know but…………4 GRAND is a lot of kabbage!
The front piece of frame is not long enough.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #170
Yup 'tis.... but is it gonna be more than $4k in aggravation LOL.
Ohh ffs :). It wouldn't cost a whole bunch to have a couple pieces bent
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
(4) Rolls of Barb Wire (A50515)
(4) Rolls of Barb...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
