New to quick hitches
/ New to quick hitches #41
Just to add to the subject…
Did anyone try to mount quick hitch inside tractor bucket? Seems to be convenient for 3 pt equipment on front
/ New to quick hitches #42
Yep. I did that and used it a few times. Having a 4-in-1 bucket I was able to rest the QH (Speeco inverted C type) into the bucket, adjust it to fit, and then chain it in place with short chain. The whole rig is not all that useful but certainly works, esp for moving attachments I do not want to hook up and want flexibility in where and what level I store them.
/ New to quick hitches #44
Got any pictures?
/ New to quick hitches #46
Bear in mind a quick hitch requires all implements to be nearly the same width. I went with Pat's Quick Hitch to eliminate that problem. I felt it was easier than modifying my implements to fit a quick hitch.
Yes, that is THE disease that makes essentially all the Speeco style (10 brands of them...) useless in my book. Nearly every time I tried to use the thing it was incompatible with the width of implement. Then there is Cat 1 , Cat 2 , etc etc. All out on the limbs of a tree I did not want to climb in the first place. Europe is a good source of ideas on this. Most or all of their quick hitches are inverted V (triangular) shape. Because of that they do not give a crap about width AND they are self-centering which is worth the entire effort for us old folks. In Europe they mount the male component on the FEL and then each implement is fitted with what amounts to an inverted V female of two pieces of C-channel. You have to see these things to understand how incredibly BETTER they are than the old cussword fixed width types. Pat's Quick Hitch (and others like it) do nothing to help with the centering problem. People like me trying to center the tractor and the 1460 lb implement after 5 tries are not impressed by those. They solve only half the problem.
Videos and YouTubes of the various ones below are super instructive.
Suggest look at Home , Jiffy Hitch Systems(Google them) or go to Jiffy Hitch Systems, Inc. , Sparex (owned by Agco) and others. Don't confuse "EuroHitch" for 3pt with the unrelated stuff for the FEL quick attach alternative to skid-steer compatibility.
The DeltaHook design and Jiffy Hitch are very similar and there is a small community that refers to all these as "Delta Hooks." Note that 'delta' is the Greek symbol for the triangle and familiar to engineers. Sparex is mostly European made but available through MF dealers. They tend to require you to weld the female inverted V to the implement. Many allow you to choose weld-on type versus pin-on type. I like the pin-on style because I can take it on and off and do not burn any bridges by welding something on there that forces you to use that type hitch in the future.
Jiffy Hitch is the best in my opinion. It is fairly expensive but so well figured out. They even have a version that ALSO connects the PTO shafts !!! Talk to Fred at Jiffy Hitch and learn from him. They offer options for pin-on and weld-on types.
Believe it or not there is even a sort of informal "hacker" club that spreads around diagrams and plans for do-it-yourself delta style quick hitches. A welder project guy's dream. See quick hitch | Farm Hack
/ New to quick hitches #47
As a relative newb myself. I looked into this and decided to try the HF and save the cash. My research told me that there were issues with older implements and the HF QH. My implements are all relatively new (Chipper and Box blade). Once I set it up (adjusting the height of the center link hitch), it works just fine. No modifications needed.
/ New to quick hitches #48
That's the one thing that's a little annoying about my Pat's QH. Trying to get those things straight is like solving a Rubik's Cube. For geniuses only. Mine are off by a little bit. One more than the other. But they solve the problem of one person implement attachments. IOW, they make it possible for one person to to attach and un-attach their implements more easily.
Yeah, I know some old-hand is gonna tell us how easy it is for him without a QH. Good on him. But for me, I like my Pat's.
That 'Euro' deal is intriguing however. But knowing nothing about the Euro hitch, I'd recommend the Pat's until something comes along that's better
There is something better. It's the Euro lower hooks as shown in the pictures. Ask anyone here on TBN that have converted to those and they will tell you right away how much better those are, even after they've uses QH and Pats.
/ New to quick hitches #49
I bought the Quick Hitch from "Harbor Fright" and it only worked on one of two of my implements. The fixed top hook would not allow one implement to fit. It sits rusting in my yard. I ended up getting Pat's QuickHitch and it is fantastic. Once you have it installed and tightered it works just as advertised. It handles my rear blade, spray rig, and 1000lb+ PTO chipper all with no problem.
/ New to quick hitches #50
What is HF QH?
/ New to quick hitches #52
Got any pictures?
Yeah, not very good but I have a few. This first one is with the 4-in-1 bucket opened up. In this mode gravity and plowing held the held the implement bottom in place while the top was a heavy bolt into clevis on top of the bucket (welded there.)
Obviously of this was going to be used much you would find a way to anchor the bottom of the Speeco in the bucket rather than depend on weight/gravity.
Did similar kludge (quickie very short term thing) for a pig pole.
Then this last one illustrates doing the same with the 4-in-1 bucket clamshell closed (which would work with any bucket. Just needs a simple top link bracket welded on the top of the bucket.)
/ New to quick hitches #53
I went with a Land Pride QH. They don't have the pin issues that other manufacturers have. The problem that I ran into was that all cat 1 implements are not the same. My solution was to make the equipment fit the hitch except for the Land Pride implements which fit their hitches. That with a hydraulic top link the only time I have to get off the tractor is to hook up the PTO.
/ New to quick hitches #54
I am, and have had no experience with them. But my new tractor has it on the FEL, so I’m considering getting one for the 3 point out back.
I only own or borrow cat 1 stuff, so is there a reason I shouldn’t get a cat 1 rated quickie?
Seems most are cat 2, and this require bushing instillation. Tractor is rated to around 3000# lift, but my implements are all under 1300#.
Also, are they truly all they’re cracked up to be? Do they introduce any noticeable up/ down or side to side slop? I know some slop side to side is ok if not good, but it bugs me. LOL
Lastly, seems there is a gulf in pricing, from under $150 to nearly $400. Very crude chunk of steel, so it’s a bit difficult to appreciate the value. Experiences?
This is you, if it fits your tractor (see attachment).If it is too large then see category one. Use bushing on equipment to bring it up to category two hitch.
/ New to quick hitches #55
I bought a quick hitch, but it does not fit any of my implements, except for a modified carryall I use to transport firewood rounds. But it is handy to drag logs out of the woods.
I see mention of the Pat’s having some binding issues. How common is this? Is this a result of improper shimming or inherent in the design?
Otherwise it’s sounding like a great solution to ease hitching up.
/ New to quick hitches #58
The quick hitch has worked out perfectly for us.
Harbor Freight Quick Hitch ($140):
Replacement top hook for it, YOU NEED THIS. It completely fixes the hookup issue that makes it not work. ($40):
Quick hitch adapter set with top bushings ($25):
Those 3 things will set you up and get your first implement adapted. You can even skip the adapter bushing kits if you don't mind the CAT 1 pins rattling around in the quick hitch a bit. Or as others have said use a piece of old plumbing pipe you may have laying around to make them.
The cost for above is entirely equivalent to a Pat's, so it comes down to preference.
If you get a hydraulic top link, the standard length will work with a Quick Hitch. You may need a slightly longer cylinder if you go Pat's.
So far all our implements recently purchased fit the QH without any changes. We don't even need to change the top hook height for any of them. Standardization seems to have happened.
I think I'd put it this way, if you are regularly running one or more implements where it simply can not be used with a quick hitch at all, then get a Pat's. If you are in the process of buying and building your yard of tools now you can just make sure it's quick hitch compatible when you buy it. Frankly, it's nice when everything just hooks up in seconds. It's just as fast as the skid steer quick attach on the front.
Had one like the harbor freight one. Destroyed it by using on an 8 ft box blade, on back of New Holland Workmaster 50 (4x4). Was backing up pushing brush and one corner of box blade found a big rock. Twisted the quick hitch into a semi-preztel. Replaced with Pat's cat. II which fits my tractor. Now if box blade finds a surprise all four tires just spin. Hydraulic middle link compliments this setup, especially when hooking / unhooking a PTO ran piece of equitment.
/ New to quick hitches #59
It's all in the installation. You have so many adjustment bolts and shims that it takes a trial installation and then when you have it mounted correctly alternate tightening the bolts to keep hookup slots straight up and down.
/ New to quick hitches #60
I took this picture to show the ends I slipped over a trailer-ball bar so it wouldn't rotate. Sleeves welded to a flat piece then bolted not welded to the trailer bar. Ten years use now and those flat pieces haven't bent, as I had worried about.
More relevant to this thread, I now have the Speeco top hook with offset pin holes (see post 21 above) on an original under $60 HF QH. The slide-in pins in the photo allow a height change for non-standard implements.
And a later addition - a HF magnet bar welded on the QH so clips and pins don't fall in the weeds.
I like having a Quick Hitch. My implements are outdoors, sometimes settled into the earth if not used for a while. Just back up and shove the implement around if needed to align it, lift the QH to hook it, and go. For the mower with a driveshaft to connect, its a little more work but NBD. TSC has a $20 PTO extender if you need more length.
Here's An old post with photos of the Speeco extended hook compared to a standard hook.
kimg1766rqh-toplinkpins-jpg.475243
Bar magnet - HF's sometimes-free 'Magnetic Tool Holder' - cut down and welded on the HF Qhitch.
20190721_153609rmagnetbarweldedtoqhitch-jpg.613928
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2201SFL (A64553)
2201SFL (A64553)
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2018 KOMATSU WA270-8 WHEEL LOADER (A65053)
2018 KOMATSU...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
