New to quick hitches
/ New to quick hitches #1
Sandroost
Member
Florida
TYM574HST now. Previously Kubota M5700, Ford 2000
I am, and have had no experience with them. But my new tractor has it on the FEL, so I’m considering getting one for the 3 point out back.
I only own or borrow cat 1 stuff, so is there a reason I shouldn’t get a cat 1 rated quickie?
Seems most are cat 2, and this require bushing instillation. Tractor is rated to around 3000# lift, but my implements are all under 1300#.
Also, are they truly all they’re cracked up to be? Do they introduce any noticeable up/ down or side to side slop? I know some slop side to side is ok if not good, but it bugs me. LOL
Lastly, seems there is a gulf in pricing, from under $150 to nearly $400. Very crude chunk of steel, so it’s a bit difficult to appreciate the value. Experiences?
/ New to quick hitches #2
You need to make a decision up front (depending on how many implements) as to whether or not you want to purchase a CAT1 quick hitch (Speeco) or get any of those that require bushings on every implement to remove the slop from the connections. Most require either the actual bushing (avail at tractor supply) that slide over the pin with a large end attached via a rollpin, or if you have clevis style attachments you may need a 1-2, and a 2-3 bushing adaptors to remove all unnecessary movement. The "fixed" bushings are like 20'ish bucks for one set and are good for one implement. The bushings are less expensive. If you only have CAT1 implements, it would probably be better to go with the Speeco which also seems to have a good reputation. The old harbor freight ones had issues with hook size and placement which made it hard to pick up some implements even though they were "quick attach" ready.
I went with whatever the dealer gave me for free and now just assume 20-30$ per attachment to make it fit correctly.
Thanks JohnnyMX- yea that was the hassle I was dealing with with my last tractor- cat 2 lift and every attachment was cat 1. Bucket o’bushings always handy. PITA.
That Speeco does look to be the ticket.
/ New to quick hitches #5
Bear in mind a quick hitch requires all implements to be nearly the same width. I went with Pat's Quick Hitch to eliminate that problem. I felt it was easier than modifying my implements to fit a quick hitch.
Pat's Quick Hitch is an awesome product, has my vote.
/ New to quick hitches #6
Many implements will be advertised as quick-hitch compatible.
For non-powered equipment, no problems. For PTO driven implements, the QH will add about 4" (given or take) to the required PTO driveshaft length. Something to consider...
I've had a QH on my tractors for at least 10 years. Although I considered telescoping lower links...I decided to stick with the QH
Most QH's are sold with an adjustable top hook nowadays...you won't want one with a welded upper hook
/ New to quick hitches #7
There has to be at least a dozen brands of CAT 1 quick hitches available..... If a CAT 1 implement does not fit the CAT1 QH its the fault of implement (manufacturer) and not the quick hitch....
Only negative I am aware of it most post hole augers will not work with QH and the QH may make it more awkward to connect up a PTO driven device like a brush hog/rear mower...
As for up/down/side slop its all in how you setup tractor arms to control motion of QH.... Very little room for up/down/side motion in QH to implement connection because of engineering standards in QH....
/ New to quick hitches #8
But it is the only one that violates the industry "standard".... You set up each implement with proper bushing once. leave bushing on implement, there is no problem.... Fix each implement once, be happy for ever...
/ New to quick hitches #9
I was never happy with the Speeco style QH. Even with all my implements set up to spec it seemed like I was always having to fiddle with something to get the implement to hook up, mostly revolving around the top hook and the angle the implement sits on the ground. Had decided to switch to the pats system but before I got them installed decided on a new tractor with telescoping links...
/ New to quick hitches #11
I'll suggest the Euro lower hooks. Those just work awesome, doesn't extend any further, no frame in the way, no need to modify implements, doesn't put things on a bind like the Pats do. It simply works and works great.
This thread has a lot of good info on these along with sources on where to get them: Upgrade Kioti DK6010SE 3-point Hitch
Lots of good information that I need to digest! Pat’s and Euros i need to look into.
I’m always leery of anything euro, except KTM and Husqvarna 😂
Wow. I’m surprised that didn’t get locked down with a patent.
Yes I watched that YouTube vid- nice introduction for a newb. 👍🏻
Ummm I thought I wanted one. I tried to order one with my tractor and my deal talked me into trying to live without one.
I am so very glad he did. Three point hitches are stupid easy.
Truly they are stupid easy. Guess I’m getting lazy and/or old. LOL
In reality, I don’t switch things up that much- 90% of the time it’ll be a rotary cutter, occasionally an old box blade and rarely a post hole digging- either of which would necessitate the quicks removal. Would mind picking up a weight box, but the cutter suffices for that pretty much though cumbersome.
I might just have case of gadgetitis.😂
/ New to quick hitches #15
Both of my compacts have been cat1 and neither had extendable arms. Hooking up my John Deere 1166 disk with the quick hitch is easy. I just set the top link at the right height (it's the one from Kenny's) and the right length. Backup, lift, and lock the levers. Without is a real pain! It is a heavy disk. The 5 foot howse was bad enough. Hooking up the 2072 is also much easier with the quick hitch. I only have to get off to hookup the pto. Same with the 54 inch tiller. I don't keep any attachments regularly mounted, but the quick hitch (it's a harbor freight) is always mounted.
Bill
/ New to quick hitches #17
If buying 2nd hand implements, farm auction stuff, ect. Most implements just need minor mods to make them work with QH. Really helps if you know a welder.
/ New to quick hitches #18
I'll second this without a doubt in my mind the nicest 3 point implement connecting there is. I even have a hydraulic top link with the Euro hook.
/ New to quick hitches #20
And for the same money you can really upgrade the mechanical 3pt hitch by putting on geared cranks for the lifting links & top link, and combine that with telescoping lower arms. For some tractors there are also alternatives to the side sway chains.
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2007 JLG 450AJ SERIES II SKYPOWER TELESCOPIC BOOM (A65056)
2007 JLG 450AJ...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
213086 (A64276)
213086 (A64276)
