New shop started
/ New shop started
Well, the “215lb Peter Wright” that I thought I owned turns out to be a 1904 or so Hay Budden.
Cleaned the patina and oiled it up. It should make someone happy (I don’t really have room for 2 anvils)
/ New shop started #532
I wonder if a machinist could grind that old anvil top nice and smooth
something elemental about an anvil. They've been around a long long time.
/ New shop started
It could be ground but it is flat enough for smith work. Sometimes dead flat (or sharp edges) aren’t your friend.
Some will mill and weld a tool steel plate to them. This survivor is just fine
/ New shop started
So I’ve had this ?heat treating? Oven for 20 years. PO had piped it directly from his inside NG line. I guess it worked but I needed to use on LP. The 18 orifices were almost 5/16”
I couldn’t get any heat or good flame. So time to make a more appropriate LP orifice(s).
18 brass orifices, 5/16-18 and #14 drill, added 2 flats (quick and dirty) for 1/4” wrench.
Size F drill to clean up and tap.
Easily went up to 1400 deg F. I probably could get a bit more out of it fiddling with a mixture, but anything above the tempering temperature is fine for me.
/ New shop started #538
Oooh! I see a geometric die head threader in your turret!
What are you going to temper?
/ New shop started
Dunno!
Just had it sitting as a project for years
Yes, good eye on die head!
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2017 Nissan Rogue AWD SUV (A59231)
2017 Nissan Rogue...
SET OF HANG ON QUICK ATTACH 48' PALLET FORKS (A59823)
SET OF HANG ON...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2000 Sterling L9513 Winch Truck (A61307)
2000 Sterling...
