New Owner 425
/ New Owner 425 #21
My brush hog is directly driven off of the hydraulic motor. It was purchased in 2001.
/ New Owner 425 #22
Actually, isn't there a spindle on the TOP of the brush hog that needs greasing?
-Rob /forums/images/graemlins/grin.gif
/ New Owner 425
I was unable to find a zerk fitting so I called the factory. They responded, "No zerk because it is the new model with direct drive." Don't know what "new" means, MossRoads is a 2001. Mine is 2004. In any event, the motor casting mounts directly on the deck. ???
/ New Owner 425 #24
I thought I saw where someone replaced the hyd motor on their mower, and even tough it is direct driven, it still turns a spindle which has at least two bearings. If the bearings are not sealed, it will have to be greased about every 8 to 15 hours.
Please correct me if your hyd motor turns that swing blade directly without going through a spindle and bearing assembly
/ New Owner 425 #25
Here's some pictures of my brush hog disassembled.
Picture of the shaft sticking up through the deck. 3 of 5 bolts installed to hold the hub underneath. The bracket for the motor and the grease zerk at the bottom left in the shadows.
Picture 2 all 5 bolts installed. Arrow pointing out grease zerk.
Picture 3 shows bottom half of love-joy connector on shaft. Rubber star sitting on top of deck waiting to be installed.
Picture 4 rubber star installed.
Picture 5 motor installed onto shaft. It had the other half of the lovejoy connector on the motor shaft already. Motor mounting bolts not installed yet.
Hope this clearly shows what I have. /forums/images/graemlins/wink.gif Is the new one different?
2007 INTERNATIONAL 9200I (A60736)
2007 INTERNATIONAL...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
2023 GMC 1500 Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC 1500...
CFG Industrial H15R (A60463)
CFG Industrial...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
