New Owner 425
/ New Owner 425 #21
My brush hog is directly driven off of the hydraulic motor. It was purchased in 2001.
/ New Owner 425 #22
Actually, isn't there a spindle on the TOP of the brush hog that needs greasing?
-Rob /forums/images/graemlins/grin.gif
/ New Owner 425
I was unable to find a zerk fitting so I called the factory. They responded, "No zerk because it is the new model with direct drive." Don't know what "new" means, MossRoads is a 2001. Mine is 2004. In any event, the motor casting mounts directly on the deck. ???
/ New Owner 425 #24
I thought I saw where someone replaced the hyd motor on their mower, and even tough it is direct driven, it still turns a spindle which has at least two bearings. If the bearings are not sealed, it will have to be greased about every 8 to 15 hours.
Please correct me if your hyd motor turns that swing blade directly without going through a spindle and bearing assembly
/ New Owner 425 #25
Here's some pictures of my brush hog disassembled.
Picture of the shaft sticking up through the deck. 3 of 5 bolts installed to hold the hub underneath. The bracket for the motor and the grease zerk at the bottom left in the shadows.
Picture 2 all 5 bolts installed. Arrow pointing out grease zerk.
Picture 3 shows bottom half of love-joy connector on shaft. Rubber star sitting on top of deck waiting to be installed.
Picture 4 rubber star installed.
Picture 5 motor installed onto shaft. It had the other half of the lovejoy connector on the motor shaft already. Motor mounting bolts not installed yet.
Hope this clearly shows what I have. /forums/images/graemlins/wink.gif Is the new one different?
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
2017 Ford E-450 Super Duty Shuttle Bus (A64556)
2017 Ford E-450...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
